FS - sandwhich oil cooler adaptors, two different styles |
GaroldShaffer |
Feb 16 2009, 10:30 PM
FS- I have two sandwhich oil cooler adaptors. #1 is like the one in this link that reatils for $37.95 on Pelican Pelican Adaptor I'm asking $25 shipped to your door since it is used.
#2 is also like the one in this link that retails for $119.95 on Pelican Pelican Adpator #2 I'm asking $80 shipped to your door since it is also used. Pics of #1 Pics of #2 |
GaroldShaffer |
Feb 16 2009, 10:31 PM
Last two pics of #2
detoxcowboy |
Feb 17 2009, 09:52 AM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Last two pics of #2 I like #2 (IMG:style_emoticons/default/drunk.gif) and have been toying with the idea, could you tell me the clearance? how far does it drop the filter?? So tight for space there.. I mean do i have to shift the engine around to make room?? or just when i changed the filter?? (IMG:style_emoticons/default/confused24.gif) |
toon1 |
Feb 17 2009, 10:31 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
PM sent for #1
GaroldShaffer |
Feb 17 2009, 11:57 AM
Last two pics of #2 I like #2 (IMG:style_emoticons/default/drunk.gif) and have been toying with the idea, could you tell me the clearance? how far does it drop the filter?? So tight for space there.. I mean do i have to shift the engine around to make room?? or just when i changed the filter?? (IMG:style_emoticons/default/confused24.gif) The adaptor is 1 3/8 inches thick. I know you can get a short oil filter that will keep everything (overall lenght) the same. I don't have the part number here. Even if you don't use the short filter the regular filter will not hang below the bottom of the engine. You will have to do some careful routing of oil lines to keep them away from the heat exchangers, but that is it. |
GaroldShaffer |
Feb 26 2009, 04:16 PM
Lo-Fi Version | Time is now: 20th May 2024 - 05:58 AM |
