OT: Am I alone in really hating this new thread format? |
LarryR |
Feb 17 2009, 10:25 AM
Senior Member Group: Members Posts: 929 Joined: 15-March 07 From: E. Bay Area, N. California Member No.: 7,604 |
I tend to try to read through most responses to a thread to eliminate duplicate content. However, with this new format one needs to click on every freakin response in the chain.
To me it seems that the new format makes the forum almost unusable? So I figured that I would throw this out there in case a little feedback might make it go back to the way it was. (IMG:style_emoticons/default/beerchug.gif) |
LarryR |
Feb 17 2009, 10:29 AM
HA! It looks like if I use IE instead of firefox it looks the way I expect it to look with no change. Does this mean that firefox pushed out a patch that breaks 914world?
URY914 |
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,598 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
New format?
Feb 17 2009, 10:30 AM
Resident German Group: Admin Posts: 41,638 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I tend to try to read through most responses to a thread to eliminate duplicate content. However, with this new format one needs to click on every freakin response in the chain. To me it seems that the new format makes the forum almost unusable? So I figured that I would throw this out there in case a little feedback might make it go back to the way it was. (IMG:style_emoticons/default/beerchug.gif) What new format? Me thinks you may have changed your view settings to "Outline". Click on the "Options" button in the top right hand corner and select "Standard" and your view should be back to normal ... (IMG:style_emoticons/default/shades.gif) Andy |
URY914 |
I use Firefox at home and IE at work and the site looks the same.
VaccaRabite |
Feb 17 2009, 10:31 AM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
You accidentally clicked a board setting that took you to a different format. Perhaps you hit "lofi format" at the bottom of the page. or Options at the top left (should be standard).
I use fire fox and everyhting is peachy. Zach |
LarryR |
Feb 17 2009, 10:32 AM
I tend to try to read through most responses to a thread to eliminate duplicate content. However, with this new format one needs to click on every freakin response in the chain. To me it seems that the new format makes the forum almost unusable? So I figured that I would throw this out there in case a little feedback might make it go back to the way it was. (IMG:style_emoticons/default/beerchug.gif) What new format? Me thinks you may have changed your view settings to "Outline". Click on the "Options" button in the top right hand corner and select "Standard" and your view should be back to normal ... (IMG:style_emoticons/default/shades.gif) Andy Hi Andy, I have not changed any settings. On the same computer if I view through firefox browser it comes up in outline. If I view through IE it looks normal. I will just use IE on 914world ... Larry |
Feb 17 2009, 10:34 AM
I have not changed any settings. On the same computer if I view through firefox browser it comes up in outline. If I view through IE it looks normal. I will just use IE on 914world ... Double check your settings in Firefox and make sure it's on "Standard" ... (IMG:style_emoticons/default/type.gif) Andy PS: I'm posting this with Firefox and my view is as it should be. |
LarryR |
Feb 17 2009, 10:36 AM
Hmm. It looks like I must have done exactly that.... Seems that maybe firefox writes a cookie to a separate location than IE. I changed the view on firefox and now it works.
(IMG:style_emoticons/default/piratenanner.gif) I was worried some new look had been rolled out. Glad to find out that it was just a mis click on my part. |
ericread |
Feb 17 2009, 11:55 AM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
I really like the new format (IMG:style_emoticons/default/blink.gif)
Especially the mustard yellow backgrounds (IMG:style_emoticons/default/aktion035.gif) |
Zimms |
Feb 17 2009, 12:18 PM
Senior Member Group: Members Posts: 1,413 Joined: 11-February 06 From: Michigan Member No.: 5,565 Region Association: Upper MidWest |
You may be talking about the outline setting for threads. Hit the options box at the start (top right) of the thread and change it back to standard.
turboman808 |
Feb 17 2009, 12:21 PM
Advanced Member Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
What I have had happen is someone post a link to another thread and there setting are set funky and it changes mine to their format. Thats probably what happened.
underthetire |
Feb 17 2009, 04:23 PM
I tend to try to read through most responses to a thread to eliminate duplicate content. However, with this new format one needs to click on every freakin response in the chain. To me it seems that the new format makes the forum almost unusable? So I figured that I would throw this out there in case a little feedback might make it go back to the way it was. (IMG:style_emoticons/default/beerchug.gif) Firefox-looks different Exploder-same as its always been |
computers4kids |
Feb 17 2009, 07:26 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I use Firefox with the Explorer rendering plugin...best of all worlds! (IMG:style_emoticons/default/piratenanner.gif)
Eric_Shea |
Feb 17 2009, 09:51 PM
QUOTE Am I alone in really hating this new thread format? yes (IMG:style_emoticons/default/biggrin.gif) |
LarryR |
Feb 17 2009, 10:14 PM
Darn computers (IMG:style_emoticons/default/type.gif)
Lo-Fi Version | Time is now: 16th May 2024 - 08:37 AM |
