FS - Bruce's Replated parts galore! UPDATED 3/6/09, Some of the best looking hardware you'll find for a 914! |
bdstone914 |
Feb 20 2009, 12:37 AM
Here is some of the parts I have had chemically stripped and replated in zinc. If you don't see something hear, PM me as I probably have it. Shipping is 5 dollars. orders over $50 get FREE SHIPPING! Also, I will buy back your used hardware. I can not offer that much for it as I am keeping the selling prices as low as I can.
Available quantities updated 3/6/09 New parts added. Front trunk upper latches $25 each. (IMG:http://img26.imageshack.us/img26/8041/dscf0840.jpg) (IMG:http://img26.imageshack.us/img26/dscf0840.jpg/1/w1280.png) Two pair of inner door latches $50 per pair or $30 each. (IMG:http://img22.imageshack.us/img22/9779/dscf0841.jpg) (IMG:http://img21.imageshack.us/img21/1464/dscf0842.jpg) (IMG:http://img21.imageshack.us/img21/dscf0842.jpg/1/w1280.png) Emergency brake ratchet part $10 each one available (IMG:http://img11.imageshack.us/img11/2571/dscf0826em4.th.jpg) Stub Axle castle nuts $25 per pair. (IMG:http://img9.imageshack.us/img9/7868/dscf0828js7.th.jpg) Emergency brake cable, equalizer cable, and bracket $30 each Three available. Bottom clip not included. (IMG:http://img10.imageshack.us/img10/9171/dscf0827mq1.th.jpg) (IMG:http://img11.imageshack.us/img11/659/dscf0790qf8.th.jpg) More getting plated SOLD OUT 1.7, 1.8, 2.0 Fuel Injector rails. (IMG:http://img10.imageshack.us/img10/5105/dscf0793jc0.th.jpg) SOLD OUT Getting more plated Complete set of CV hardware. (IMG:http://img9.imageshack.us/img9/8618/dscf0794xk4.th.jpg) Small Air Box Clips, $2.50 each (IMG:http://img10.imageshack.us/img10/368/dscf0799xp2.th.jpg) Rear Trailing arm shims to set rear camber. set of two 2mm, two 4mm. $25 set, 1 set available. Many 4 mm shims available (IMG:http://img9.imageshack.us/img9/5778/dscf0809rj9.th.jpg) Sold out of latches with new bushings. I have good used bushings and will have new bushings in one week. Taking orders Rebuilt upper rear trunk latches with new Delrin bushings. $25 each. (IMG:http://img8.imageshack.us/img8/2321/dscf0811dg6.th.jpg) Temporally sold out. Complete set of rear transmission hardware. 1 set available $25 dollars a set (IMG:http://img6.imageshack.us/img6/7306/dscf0819pj1.th.jpg) Getting more palted Taking orders Front strut mounting hardware.1 set needed per car. $10 without bolts. several sets available w UPDATE! more parts! (IMG:http://img25.imageshack.us/img25/8752/dscf0777mb0.th.jpg) Front Trunk lower latch. 2 Different styles. I believe the one on the right is from early years and correct for a 6. $25 each. (IMG:http://img17.imageshack.us/img17/1378/dscf0786hu9.th.jpg) Engine Lid Latch. $15 each. (IMG:http://img16.imageshack.us/img16/9969/dscf0788ju1.th.jpg) Tranny Plate. $25. Only one available. (IMG:http://img15.imageshack.us/img15/2157/dscf0789mp8.th.jpg) SOLD Tortion bar adjusters/caps. $20 per pair.[/s] (IMG:http://img24.imageshack.us/img24/5518/dscf0792xv0.th.jpg) NLA Gas Tank Strap hardware. $15 No straps sorry. (IMG:http://img23.imageshack.us/img23/2575/dscf0795ql0.th.jpg) Front Headlight hardware plates. $7.50 per pair. Only silver available. (IMG:http://img22.imageshack.us/img22/5036/dscf0802ug3.th.jpg) Pedal Board Rubber stop holder. $10 each. (IMG:http://img21.imageshack.us/img21/2830/dscf0803ad2.th.jpg) from Left to right, (IMG:http://img23.imageshack.us/img23/7398/dscf0808be3.th.jpg) Spare Tire hold down hardware. $11 for the set. There sets available. (IMG:http://img14.imageshack.us/img14/1323/dscf0838mo2.th.jpg) Heater blower clamps for engine compartment fan $10 (IMG:http://img11.imageshack.us/img11/1295/dscf0826mb1.th.jpg) SOLD Fuel injector hold downs. $15 for a set of four. One is plated in flat zinc the others are bright zinc. (IMG:http://img10.imageshack.us/img10/7838/dscf0829kp3.th.jpg) S branch brackets. No gaskets. $5 each. (IMG:http://img9.imageshack.us/img9/5356/dscf0833ey0.th.jpg) (IMG:http://img10.imageshack.us/img10/8684/dscf0834hv7.th.jpg) Traling arm L shaped thingies. $5 per pair Three gold three silver. (IMG:http://img9.imageshack.us/img9/3923/dscf0835kw4.th.jpg) Brake reservior strap. $15. Near perfect. Silver (IMG:http://img6.imageshack.us/img6/5118/dscf0837bp2.th.jpg) Ball joint retainer clips $15 per pair Reasonable offers accepted on package deals. Preferred payment method is Paypal to BDStone914@aol.com. Checks accepted to Bruce Stone 11276 Ramway Rd Riverside CA 92505 Combined shipping for US will be just $5 dollars. Shipping at cost to others countries. 25% discount and free shipping on orders over $100. |
koozy |
Feb 20 2009, 02:03 AM
Senior Member Group: Members Posts: 651 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
Them are some might fine looking parts, Bruce.
jesiv |
Feb 20 2009, 08:54 AM
Senior Member Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California |
Bruce,
Front strut mounting hardware. 2 sets available. $15 set complete $10 without bolts. several sets available without bolts. Do I need one or two sets to do the front? Regards, James |
bdstone914 |
Feb 20 2009, 09:16 AM
jeeperjohn56 |
Feb 20 2009, 09:34 AM
Member Group: Members Posts: 479 Joined: 9-July 06 From: Antioch,Ca. Member No.: 6,407 Region Association: None |
Hey Bruce, I'll take a set of the strut mounting with bolts. also the trans mounts, would that be $5.00 sh for both? will send paypal John (IMG:style_emoticons/default/driving.gif)
JRust |
Feb 20 2009, 12:06 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I'll take one set of 2.0 FI rails
One set of the CV hardware. One set of the upper front strut mounts with Bolts! How do you want the $55 ? Paypal or check in the mail? |
bdstone914 |
Feb 20 2009, 01:00 PM
UPDATE! more parts!
jesiv |
Feb 20 2009, 01:58 PM
Bruce,
I'll take the Front strut mounting hardware.1 set needed per car. $15 set complete Regards, James |
biosurfer1 |
Feb 20 2009, 02:17 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
any chance you have the engine bar (sideshift) mounting hardware that goes through the suspension ears?
Heeltoe914 |
Feb 20 2009, 02:19 PM
Senior Member Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
Bring up a box of stuff when you get the cluster done. Looks great as always.
Rob914 |
Feb 21 2009, 07:02 AM
Member Group: Members Posts: 113 Joined: 8-April 03 From: Lake Villa, IL Member No.: 541 Region Association: None |
Bruce,
I will take a set of the rear trailing arm shims and the gas tank strap hardware. I am also interested in a set of fuel injector rails. From the picture it appears that the two sets you have may be different. If they are different, do you have a set that originally came with a 1971 1.7? Please let me know and I will send payment. Thanks, Rob |
bdstone914 |
Feb 21 2009, 10:33 AM
Bruce, I will take a set of the rear trailing arm shims and the gas tank strap hardware. I am also interested in a set of fuel injector rails. From the picture it appears that the two sets you have may be different. If they are different, do you have a set that originally came with a 1971 1.7? Please let me know and I will send payment. Thanks, Rob Rob, The FI rails are the same for all years. The two pairs pictured are the same but positioned differently. I am posting a picture of the gas tank hold down which are $15. Bruce |
Nor.Cal.914 |
Feb 21 2009, 01:22 PM
1975 914 3.0SC Group: Members Posts: 1,050 Joined: 28-January 05 From: Weatherford, TX Member No.: 3,523 Region Association: None |
Is the spare tire hold down and the clutch pedal rubber stop holder still available? Does the pedal stop come with the rubber in it? Please let me know. Thanks
-Chris |
bdstone914 |
Feb 21 2009, 01:53 PM
Is the spare tire hold down and the clutch pedal rubber stop holder still available? Does the pedal stop come with the rubber in it? Please let me know. Thanks -Chris Yes I still have those parts. I may have a rubber stop that I can include. I have several spare tire hold down plates. I will be away from the computer for most of the day. Call if if you want to discuss cell (nine five one) - 536-7478 |
Nor.Cal.914 |
Feb 21 2009, 06:51 PM
I will take a spare tire hold down set and if you have a good piece of rubber for the pedal stop, I will take one of those as well. Is shipping $5 for everything? Please let me know. Thanks
-Chris |
harlenl |
Feb 21 2009, 09:59 PM
Member Group: Members Posts: 91 Joined: 6-February 04 From: Santa Cruz, CA Member No.: 1,640 |
Hey Bruce, sent you a PM for a trunk latch
bdstone914 |
Feb 23 2009, 01:14 AM
Availability updated 3/8/09 I have six more rear upper trunk latches with new Delrin bushings Priority goes to those you request them previously. (IMG:http://img22.imageshack.us/img22/3931/dscf0888f.th.jpg) Here is some of the parts I have had chemically stripped and replated in zinc. If you dont see something hear, PM me as I probably have it. Shipping is 5 dollars. orders over $50 get FREE SHIPPING! Also, I will update this thread with more and more parts so check back soon! Rear Trailing arm shims to set rear camber. set of two 2mm, two 4mm. $4 each, 5 2mm, 16 4mm shims http://img25.imageshack.us/img25/3125/dscf0865.jpg http://img14.imageshack.us/img14/3125/dscf0865.jpg Emergency brake ratchet part $10 each two available (IMG:http://img11.imageshack.us/img11/2571/dscf0826em4.th.jpg) Stub Axle castle nuts $25 per pair. (IMG:http://img9.imageshack.us/img9/7868/dscf0828js7.th.jpg) Emergency brake cable, equalizer cable, and bracket $30 each Three available. Bottom clip not included. (IMG:http://img10.imageshack.us/img10/9171/dscf0827mq1.th.jpg) (IMG:http://img11.imageshack.us/img11/659/dscf0790qf8.th.jpg) SOLD OUT 1.7, 1.8, 2.0 Fuel Injector rails. (IMG:http://img10.imageshack.us/img10/5105/dscf0793jc0.th.jpg) SOLD OUT Complete set of CV hardware. (IMG:http://img9.imageshack.us/img9/8618/dscf0794xk4.th.jpg) Small Air Box Clips, $2.50 each (IMG:http://img9.imageshack.us/img9/5778/dscf0809rj9.th.jpg) Rebuilt upper rear trunk latches with new Delrin bushings. $25 each. (IMG:http://img6.imageshack.us/img6/7306/dscf0819pj1.th.jpg) No sets with bolts available. Front strut mounting hardware.1 set needed per car. $10 without bolts. several sets available w UPDATE! more parts! (IMG:http://img25.imageshack.us/img25/8752/dscf0777mb0.th.jpg) Front Trunk lower latch. 2 Different styles. I believe the one on the right is from early years and correct for a 6. $25 each. (IMG:http://img17.imageshack.us/img17/1378/dscf0786hu9.th.jpg) Engine Lid Latch. $15 each. (IMG:http://img16.imageshack.us/img16/9969/dscf0788ju1.th.jpg) Tranny Plate. $25. Only one available. (IMG:http://img15.imageshack.us/img15/2157/dscf0789mp8.th.jpg) SOLD Tortion bar adjusters/caps. $20 per pair.[/s] (IMG:http://img24.imageshack.us/img24/5518/dscf0792xv0.th.jpg) NLA Gas Tank Strap hardware. $15 No straps sorry. (IMG:http://img23.imageshack.us/img23/2575/dscf0795ql0.th.jpg) Front Headlight hardware plates. $7.50 per pair. Only silver available. (IMG:http://img22.imageshack.us/img22/5036/dscf0802ug3.th.jpg) Pedal Board Rubber stop holder. $10 each. (IMG:http://img21.imageshack.us/img21/2830/dscf0803ad2.th.jpg) from Left to right, Brake reservoir strap, $15, 70-74 Fuel pump bracket $10, Fan mounted coil straps $10. several coil straps available. (IMG:http://img23.imageshack.us/img23/7398/dscf0808be3.th.jpg) Spare Tire hold down hardware. $11 for the set. There sets available. (IMG:http://img14.imageshack.us/img14/1323/dscf0838mo2.th.jpg) Heater blower clamps for engine compartment fan $10 (IMG:http://img11.imageshack.us/img11/1295/dscf0826mb1.th.jpg) (IMG:http://img9.imageshack.us/img9/5356/dscf0833ey0.th.jpg) (IMG:http://img10.imageshack.us/img10/8684/dscf0834hv7.th.jpg) Traling arm L shaped thingies. $5 per pair Three gold three silver. free shipping if other parts are bought. (IMG:http://img9.imageshack.us/img9/3923/dscf0835kw4.th.jpg) Brake reservior strap. $15. Near perfect. Silver pictured also have a gold one in same condition (IMG:http://img6.imageshack.us/img6/5118/dscf0837bp2.th.jpg) Ball joint retainer clips $15 per pair Reasonable offers accepted on package deals. Preferred payment method is Paypal to BDStone914@aol.com. Combined shipping for US will be just $5 dollars. Shipping at cost to others countries. 25% discount and free shipping on orders over $100. Bump - more parts added |
jim_hoyland |
Feb 24 2009, 07:12 PM
Get that VIN ? Group: Members Posts: 9,302 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Bruce usually attends the G & R swapmeet each year in April; his inventory is worth looking at when rebuilding or just upgrading parts on a 914. |
bdstone914 |
Feb 24 2009, 09:56 PM
(IMG:style_emoticons/default/icon_bump.gif) Bruce usually attends the G & R swapmeet each year in April; his inventory is worth looking at when rebuilding or just upgrading parts on a 914. To all those in SoCal that may not be aware of it there is a Porsche swap meet March 8 8AM at the Phoenix Club in Anaheim. I do have lots of parts and can bring requested parts there for pickup. Bruce |
Bucci |
Feb 24 2009, 10:44 PM
Bucci Group: Members Posts: 106 Joined: 11-August 08 From: Carlsbad,Ca Member No.: 9,407 Region Association: Southern California |
Hello Bruce,
I will take the rear transmission hardware and please bring it to the swap in Anaheim, Ca..... Best Marc 619-726-9012 |
Lo-Fi Version | Time is now: 20th May 2024 - 02:04 AM |
