Available quantities updated 3/6/09
New parts added.
Front trunk upper latches $25 each.
Two pair of inner door latches $50 per pair or $30 each.
Emergency brake ratchet part $10 each one available
Stub Axle castle nuts $25 per pair.
Emergency brake cable, equalizer cable, and bracket $30 each
Three available. Bottom clip not included.
More getting plated SOLD OUT
1.7, 1.8, 2.0 Fuel Injector rails.
SOLD OUT Getting more plated
Complete set of CV hardware.
Small Air Box Clips, $2.50 each
Rear Trailing arm shims to set rear camber. set of two 2mm, two 4mm. $25 set, 1 set available. Many 4 mm shims available
Sold out of latches with new bushings. I have good used bushings and will have new bushings in one week.
Taking orders
Rebuilt upper rear trunk latches with new Delrin bushings. $25 each.
Temporally sold out.
Complete set of rear transmission hardware. 1 set available $25 dollars a set
Getting more palted
Taking orders
Front strut mounting hardware.1 set needed per car. $10 without bolts. several sets available w
UPDATE! more parts!
Front Trunk lower latch. 2 Different styles. I believe the one on the right is from early years and correct for a 6. $25 each.
Engine Lid Latch. $15 each.
Tranny Plate. $25. Only one available.
SOLD
Tortion bar adjusters/caps. $20 per pair.[/s]
NLA Gas Tank Strap hardware. $15 No straps sorry.
Front Headlight hardware plates. $7.50 per pair. Only silver available.
Pedal Board Rubber stop holder. $10 each.
from Left to right,
Spare Tire hold down hardware. $11 for the set. There sets available.
Heater blower clamps for engine compartment fan $10
SOLD
Fuel injector hold downs. $15 for a set of four. One is plated in flat zinc the others are bright zinc.
S branch brackets. No gaskets. $5 each.
Traling arm L shaped thingies. $5 per pair Three gold three silver.
Brake reservior strap. $15. Near perfect. Silver
Ball joint retainer clips $15 per pair
Reasonable offers accepted on package deals.
Preferred payment method is Paypal to BDStone914@aol.com.
Checks accepted to
Bruce Stone
11276 Ramway Rd
Riverside CA 92505
Combined shipping for US will be just $5 dollars. Shipping at cost to others countries.
25% discount and free shipping on orders over $100.
