rear brake hose removal |
parrish911 |
Feb 20 2009, 03:07 PM
Newbie Group: Members Posts: 35 Joined: 27-April 06 Member No.: 5,939 Region Association: South East States |
I discovered I have leaking rear brake hoses on my '73. They are original. I have replacements ready to install, but have been struggling with breaking loose the connection furthest from the rear caliper. This connection is vertical and just under the sheet metal separating the top and bottom of the engine.
Anyone have any tricks or advice on how best to break the connection? I did purchase flared nut wrenches, but there is not much elbow room to generate the torque needed. Help. Steve |
Kansas 914 |
Feb 20 2009, 03:15 PM
I discovered I have leaking rear brake hoses on my '73. They are original. I have replacements ready to install, but have been struggling with breaking loose the connection furthest from the rear caliper. This connection is vertical and just under the sheet metal separating the top and bottom of the engine. Anyone have any tricks or advice on how best to break the connection? I did purchase flared nut wrenches, but there is not much elbow room to generate the torque needed. Help. Steve Since your hose is "hosed" - just cut it off near the upper fitting and use a socket. A tip I learned from Eric Shea! |
Lo-Fi Version | Time is now: 17th May 2024 - 08:02 PM |
