starting trouble |
starting trouble |
jea69 |
Feb 22 2009, 10:27 AM
doing unspeakable things to iron Group: Members Posts: 51 Joined: 13-March 08 From: norway Member No.: 8,811 Region Association: Scandinavia |
need some help here , my car dont start , its a 70 1,7 d jet. at first when i turned the key to on ,everything powers up ,lights ,pump etc, the car fired up ,but when i released the key it just died , this happened a couple of times, now it wont start at all, (starter motor ,pump n light works). i suspected the starter switch , but when i pulled the plugs to check they were dry. there is no triggernoise from the cold start injector when i move the trottle . is this starterswitch related (IMG:style_emoticons/default/confused24.gif) do the injectors loose power due to a faulty switch ?
Jeffs9146 |
Feb 22 2009, 10:39 AM
Put the car in neutral, turn the key on and use the screwdriver trick to jump the starter under the car. If it starts then it is probably the switch or a bad ground. Check all of your grounds and the voltage/condition of the battery.
Switch & Solinoid Problem |
swl |
Feb 22 2009, 11:22 AM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
really sounds like the ignition switch. consistent with your symptoms. could also be the relay board. A little hunting with a voltmeter will tell the story. Start with the ignition coil and work backwards.
dkjens |
Feb 22 2009, 11:24 AM
Member Group: Members Posts: 159 Joined: 24-November 08 From: Pasadena, CA Member No.: 9,785 Region Association: None |
WOW, a '70 914 has survived in Norway. Sorry, just blew my mind.
jea69 |
Feb 22 2009, 11:43 AM
really sounds like the ignition switch. consistent with your symptoms. could also be the relay board. A little hunting with a voltmeter will tell the story. Start with the ignition coil and work backwards. thanks ,will do that , ill replace the switch also ,if it aint broken will be soon annyway (IMG:style_emoticons/default/biggrin.gif) with 4 feet of snow outside ,i aint going anywere soon (IMG:style_emoticons/default/dry.gif) |
jea69 |
Feb 22 2009, 11:48 AM
WOW, a '70 914 has survived in Norway. Sorry, just blew my mind. yea this is the last one ,the rest of them have been eaten by polar bears (IMG:style_emoticons/default/chowtime.gif) |
ericread |
Feb 22 2009, 12:42 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Isn't it the middle of winter in Norway and about 100 degrees below zero right now? Are you expecting it to start?????
(IMG:style_emoticons/default/beerchug.gif) |
jea69 |
Feb 22 2009, 01:00 PM
Isn't it the middle of winter in Norway and about 100 degrees below zero right now? Are you expecting it to start????? (IMG:style_emoticons/default/beerchug.gif) guess your right , tomorrow i vil fire up my reindeers going to work (IMG:style_emoticons/default/biggrin.gif) people shouldent be living here exept in summertime (IMG:style_emoticons/default/smile.gif) btw found the problem : it was a bad relay , the one feeding the injection power. thanks all for guiding me to the solution. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 07:54 PM |
