need some help here , my car dont start , its a 70 1,7 d jet. at first when i turned the key to on ,everything powers up ,lights ,pump etc, the car fired up ,but when i released the key it just died , this happened a couple of times, now it wont start at all, (starter motor ,pump n light works). i suspected the starter switch , but when i pulled the plugs to check they were dry. there is no triggernoise from the cold start injector when i move the trottle . is this starterswitch related
do the injectors loose power due to a faulty switch ?
