late 914 odometer trip reset, Where is it supposed to be located |
johnnie5 |
Feb 22 2009, 04:45 PM
914 lover Group: Members Posts: 375 Joined: 14-October 08 From: San Diego, CA Member No.: 9,644 Region Association: Southern California |
My 75 trip reset is hanging under the dash and doesn't have any kind of knob or end on it. It does function properly but it is just basically a threaded rod, hanging by the cable. Where is the stock mounting place for it and what type of knob/end does it have? (IMG:style_emoticons/default/idea.gif)
Lightly circled in pic Attached image(s) |
Joe Bob |
Feb 22 2009, 04:57 PM
Spin it....
johnnie5 |
Feb 22 2009, 05:02 PM
Joe Bob |
Feb 22 2009, 05:05 PM
Grasp the cable between your thumb and forefinger...spin it like a pencil.
If the cable is seated in the back of the gauge AND the odometer still works, it will roll the 3 digits until they all hit equal numbers and eventually all zeros will turn up. |
southernmost914 |
Feb 22 2009, 05:07 PM
KEY WEST/HAVANA Tunnel Authority Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States |
You used to have A/C. That is the extention you have circled. (IMG:style_emoticons/default/biggrin.gif) I can find no part # for the missing knob.
Steve |
johnnie5 |
Feb 22 2009, 08:23 PM
You used to have A/C. That is the extention you have circled. (IMG:style_emoticons/default/biggrin.gif) I can find no part # for the missing knob. Steve Thanks Steve, that makes sense. I did have A/C and have since deleted the lower dash with the vents. So this extension somehow obviously fastened to that lower dash. I guess at this point I am going to wing it and custom mount it somehow and find some kind of knob/fastener for the end to operate it. I would still like to know what the stock factory application is... |
904svo |
Feb 22 2009, 08:28 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
There's a mounting hole on the bottom of the dash under the cigarette lighter
thats where it mounts. |
southernmost914 |
Feb 22 2009, 08:41 PM
The extendtion mounts with a set screw and yes there is the original mounting hole you will see under the dash. Cut the extendtion short and use it has the knob and to hold it in its original mounting hole/bracket. Just a thought (IMG:style_emoticons/default/bye1.gif)
Steve |
charliew |
Feb 22 2009, 11:36 PM
My 75 has it sticking through the front of the dash to the right of the steering column. My car also had ac.
Racer |
Feb 23 2009, 08:59 AM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
A/C was a dealer installed accesory. Therefore, how the "dealer" handled the trip odometer cable may vary.
Lo-Fi Version | Time is now: 17th May 2024 - 08:19 PM |
