Easy Questions..., SSt HE's and Stock Front Sway Bars |
19144jt |
Feb 25 2009, 04:56 PM
Member Group: Members Posts: 176 Joined: 19-September 05 From: Grass Valley, CA Member No.: 4,829 |
Hello evryone, It's been a while since I've been to this site. My 1975 I have had that needs restoration finally has a new home in my new detached garage. I have spent the last two weeks going through the many $$$$ worth of new and used parts I've been collecting for restoration. I have two questions:
1. When we talk about stainless heat exchangers are we talking about only the outer cover (heat exchanger portion) or the exhaust pipe portion where the exhause goes through too? I have 2 sets of the heat exchanger sections of the exhuast and the covers where the heated air is produced for the cabin are satinless but the exhause pipes that are under these covers are plain steel. 2. Were there different sizes of front sway bars from the factory or just the 15mm? Thanks, John |
SLITS |
Feb 25 2009, 05:20 PM
#1.) I think they were made both ways. A magnet is your friend to find out what the metal is. I have a set that are SS, but the flanges are magnetic. Go figure.
#2.) 15 mm is the standard as far as I've seen. There were some 19mm bars, but I believe they came on 911s. |
JoeSharp |
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
My SS heat exchangers were Stainless Steel headers and covers. If they are used and look burned they will look like they are steel. Use a magnet.
There several size front sway bars. 15 mm are the stock 914 bars. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:44 PM |
