Muffler bracket question |
dbgriffith75 |
Feb 25 2009, 10:08 PM
TheGrif Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest |
johnnie5 |
Feb 25 2009, 10:22 PM
914 lover Group: Members Posts: 375 Joined: 14-October 08 From: San Diego, CA Member No.: 9,644 Region Association: Southern California |
Yes, they are different. I have a 75 that had a 1.8, and just installed a McMark 2056 and also backdated my heat exchangers and exhaust to 73-74 2.0 for better performance. I did have to acquire an early muffler bracket for it all to work.
dbgriffith75 |
Feb 25 2009, 10:32 PM
Yes, they are different. I have a 75 that had a 1.8, and just installed a McMark 2056 and also backdated my heat exchangers and exhaust to 73-74 2.0 for better performance. I did have to acquire an early muffler bracket for it all to work. I guess I should have clarified that, and maybe it doesn't make a difference, but it's going from a 2.0 to a 2.0, the only difference is the years. So are they different in that case? |
SLITS |
Feb 25 2009, 10:37 PM
The '73-'74 2.0 exhaust system is different than the '75-'76 2.0 exhaust system.
You have a single pipe coming down each side to the muffler with a flange and as I remember, it is triangular. The '73 - '74 has two pipes per side. They take different muffler / HE supports. |
dbgriffith75 |
Feb 26 2009, 08:21 AM
Thanks
jcd914 |
Feb 26 2009, 10:25 AM
There are 3 different muffler brackets for 4cyl 914s.
1.7L/1.8L engines 70 - 74 2.0L engines 73 - 74 1.8L/2.0L engines 75 - 76 Their use is dependent on the heat exchangers installed rather that the engine. So if you are using a the HEs off the 75 then the 75 bracket will work but if you are using the HEs off 73/74 then you need the bracket for a 73/74. Jim |
Lo-Fi Version | Time is now: 17th May 2024 - 07:31 PM |
