Targa Top side seal & the Mini-Me seal, A tale of two seals |
RickS |
Feb 28 2009, 01:14 AM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Gentlemen and sundry ner-do wells,
Got tired of my mobile swimming pool after every monsoon and broke down and bought new side seals from the Pelican. After reading a couple informative, and a couple of pathetic threads, there was no answer about the Mini-me seal. There is the thick inner main seal and then the very thin lip-like outer (Mini-Me) thin seal. My question - since the old seals only had the thick inner seal - is the window glass supposed to seat between the thick inner and the thin inner seal? If so, how do I get the outer seal to relax a bit so the glass can slide in between? Or is the glass just supposed to press against the outer thin lip? Pathetic pic of the offender with a wire inserted to spread the proverbial lips (IMG:style_emoticons/default/unsure.gif) : Attached thumbnail(s) |
JoeSharp |
Feb 28 2009, 03:39 AM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
The glass just comes up to the seal and rest against it.
Mikey914 |
Feb 28 2009, 03:43 AM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The glass just comes up to the seal and rest against it. Actually, the profile should allow for the glass to have just enough clearance to pass under the small seal. There will be a little resistance when the door is opened as the glass is pushed out again. This picture is with the 3 part main seal removed. You are looking at the front of the passenger window. There's about 1/16-1/8" of the glass under the "mini-me seal" Attached thumbnail(s) Attached image(s) |
Joe Owensby |
Feb 28 2009, 10:10 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
Does the glass flip back inside the small outer lip when it the door is closed with the glass up? I have some new seals that have the lip, but it is pretty close to the inner lip, and the glass can not go between the two.
Thanks, JoeO |
Mikey914 |
Feb 28 2009, 10:45 PM
Mine was designed to go inside the gap between the two, so that you have 2 barriers. The mini seal on the outside, so if the water gets past the 1st barrier, it then has to go against gravity to get over the top of the glass to get into the inside. You will also notice that the seal in the track is tight enough that it bows up forcing the gap open between the 2 seals. Knd of a pain to put in, but works well.
RickS |
Mar 1 2009, 01:02 AM
Because the inner and outer lips are pressed together - I will try 'relaxing' the outer from the inner by placing a coax cable between the two, so they resemble the pics you good chaps posted.
Thanks again. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:41 PM |
