Supra motor in my porche?!?!? |
Madsupra88 |
Mar 3 2009, 11:21 AM
Newbie Group: Members Posts: 5 Joined: 4-December 07 From: Detroit, MI Member No.: 8,421 |
Whatsup guys
Im just throwing some ideas around on what to do with the porche. i have a fully built supra motor (inline 6) i was wondering if it would be possible to fit that in the 914? You guys know a hole lot more then me on this porche so any help would be appreciated. -saif |
Mar 3 2009, 12:13 PM
Resident German Group: Admin Posts: 41,641 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Whatsup guys Im just throwing some ideas around on what to do with the porche. i have a fully built supra motor (inline 6) i was wondering if it would be possible to fit that in the 914? You guys know a hole lot more then me on this porche so any help would be appreciated. -saif My wild guess would be that a inline /6 is too long to fit unless you plan to do some major cutting and welding. Also, i'm not sure why you would want a motor on your Porch in the first place, but you said it already had a hole? (IMG:style_emoticons/default/poke.gif) Andy Attached image(s) |
smontanaro |
Mar 3 2009, 12:25 PM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
You guys know a hole lot more then me ... "hole" being the operative keyword. You'll almost certainly need a big hole somewhere to get that long motor into a teener. In fact, unless you want the hole in the firewall so you can get all cuddly with it, I suspect you might need to stretch the wheelbase. I think there is a good reason that most early 6 conversions where either 911 motors or Buick V6s... Hmmm... Why aren't V6 conversions popular anymore? Skip |
Madsupra88 |
Mar 3 2009, 07:42 PM
You guys know a hole lot more then me ... "hole" being the operative keyword. You'll almost certainly need a big hole somewhere to get that long motor into a teener. In fact, unless you want the hole in the firewall so you can get all cuddly with it, I suspect you might need to stretch the wheelbase. I think there is a good reason that most early 6 conversions where either 911 motors or Buick V6s... Hmmm... Why aren't V6 conversions popular anymore? Skip Hah i was just tinkering with the idea a little bit, im not trying to do heavy modification, so i guess its out of the question. I guess ill throw in the stroked 383. thanks guys -saif |
RJMII |
Mar 3 2009, 07:44 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
a stroked 383 isn't something that requires heavy modifications?
LarryR |
Mar 3 2009, 09:05 PM
Senior Member Group: Members Posts: 929 Joined: 15-March 07 From: E. Bay Area, N. California Member No.: 7,604 |
You guys know a hole lot more then me ... "hole" being the operative keyword. You'll almost certainly need a big hole somewhere to get that long motor into a teener. In fact, unless you want the hole in the firewall so you can get all cuddly with it, I suspect you might need to stretch the wheelbase. I think there is a good reason that most early 6 conversions where either 911 motors or Buick V6s... Hmmm... Why aren't V6 conversions popular anymore? Skip Hah i was just tinkering with the idea a little bit, im not trying to do heavy modification, so i guess its out of the question. I guess ill throw in the stroked 383. thanks guys -saif (IMG:style_emoticons/default/lol-2.gif) why in the world would you need that much of a torque beast in a 914? BTW the 901 was never meant to hold up to 500 ft lb of torque... for that much grunt you need a beefy trans like a 930 box (not cheap and even more expensive to make it work in a 914) You will need to stiffen the chasis, You will need to stop the monster, you will need huge rubber on the ground... on and on... I think a big v8 done right is somewhere in the neighborhood of 30K ... |
Mar 3 2009, 09:23 PM
I think a big v8 done right is somewhere in the neighborhood of 30K ... (IMG:style_emoticons/default/agree.gif) |
byndbad914 |
Mar 4 2009, 02:32 AM
shoehorn and some butter - it fits Group: Members Posts: 1,547 Joined: 23-January 06 From: Broomfield, CO Member No.: 5,463 Region Association: None |
I think a big v8 done right is somewhere in the neighborhood of 30K ... (IMG:style_emoticons/default/agree.gif) you guys mean the whole conversion for $30K, not just the engine, right? cuz I can build a 500HP/500ft-lb 383 for under $10K completely streetable with a hyd roller cam on pump gas, probably carb to pan, fired up on the dyno for around $8K with killer aftermarket cylinder heads and so forth. I have only $10K in my engine carb to pan, everything needed to fire on the dyno including shaft mount rockers and a belt drive, etc overkill items for a 500HP 383. |
Mar 4 2009, 02:39 AM
you guys mean the whole conversion for $30K, not just the engine, right? "for that much grunt you need a beefy trans like a 930 box (not cheap and even more expensive to make it work in a 914) You will need to stiffen the chasis, You will need to stop the monster, you will need huge rubber on the ground... on and on..." So yes, if done right, for the whole conversion. Pretty much the same for a big /6. Once you get into the 300HP+ range, there's all sorts of more or less expensive things you are going to want to add ... (IMG:style_emoticons/default/shades.gif) Andy |
ArtechnikA |
Mar 4 2009, 09:20 AM
Hmmm... Why aren't V6 conversions popular anymore? Probably because you still have to do just as much plumbing and adapter stuff, and cheap plentiful V8s fit fine. If there were more cheap powerful 60º V6s it might be a different story, but I just can't see going to all that work just to put in a 90º V6 that will never run right... |
Lo-Fi Version | Time is now: 17th May 2024 - 09:41 PM |
