solid motor mounts |
southern 914 |
Feb 23 2004, 09:36 PM
Newbie Group: Members Posts: 1 Joined: 23-February 04 From: Tucson Az Member No.: 1,705 |
I have a 914-6 conversion (IMG:style_emoticons/default/rolleyes.gif) But it is about to eat it's second oil pressure sender (IMG:style_emoticons/default/mad.gif) It has been sugested that I put in some rubber mounts that the solid ones pass to much vibration to the sender. If I stay with this setup I should mount the sender to the firewall. Also I have the CIS injection, they tell me this also does not like the vibration but it sure runs strong at the track.
What are ideas you all have - solid or rubber. What does solid mounts really do for you. Haven't seen this thread before. Thanks in advance |
Qarl |
Feb 23 2004, 09:44 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Solid will make the vibrations worse. Go with the 911 type sport mounts...
(IMG:http://i8.ebayimg.com/01/i/01/63/48/bb_1.JPG) |
Feb 23 2004, 11:13 PM
Resident German Group: Admin Posts: 41,633 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
yupp, the above sport mounts might be what you're looking for.
solid mounts give you a better, more "precise" feeling in the shifting cause you take away some sluggishness in the shifter-rod assembly. i have the 911 sport mounts and me likes 'em. (IMG:style_emoticons/default/cool.gif) Andy |
Mark Henry |
Feb 24 2004, 07:12 AM
Yep, us bug guys have known this for years.
Solid mounts just ends up breaking shit. Why do you think you have to tighten all the nuts on an old Harley every week. (IMG:style_emoticons/default/cool_shades.gif) |
Mike D. |
Feb 24 2004, 06:04 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
another question along this same line....
What if "someone" was to use solid transmision mounts and the rubber engine mounts, any advantages? pros, cons? still no good? -Mike D. |
Mueller |
Feb 24 2004, 06:51 PM
QUOTE What if "someone" was to use solid transmision mounts and the rubber engine mounts, any advantages? pros, cons? still no good? lot's of us run this combo up here in NorCal since the rules allow it.....solid motor mounts are a no-no in most classes, yet they say nothing about running solid transmission mounts (IMG:style_emoticons/default/wink.gif) |
campbellcj |
Feb 25 2004, 01:00 AM
I can't Re Member Group: Members Posts: 4,544 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Same here; sport (911) front motor mounts, solid rears.
I think a few 914 guys run solid mounts all around, but that seems like the exception. It supposedly helps even more with the syndrome where you can't find a gear when the car is under a lot of load, like under decel into an uphill or downhill turn. |
maf914 |
Feb 25 2004, 08:08 AM
I have read somewhere (?) that solid mounts can lead to cracked/failed tranny mounting ears. Anyone know if there's any truth to that?
Also, I've seen the Weltmeister solid tranny mounts. They appear to be a block of polyurethane with a bolt through it. It looks like they are solid in tension but would flex a bit in compression. Are these considered solid or flexible? Are they any good? Mike |
seanery |
Feb 25 2004, 08:12 AM
Mike,
I've got SOLID tranny mounts, there is no rubber at all. Maybe you're thinking of the sport mounts? This is the mount (it's not put together right in this pic). (IMG:http://www.914world.com/bbs2/uploads/post-2-1065801716.jpg) |
maf914 |
Feb 25 2004, 10:01 AM
Sean,
I understand. Some racers use various fabbed mounts like yours, ether steel or aluminum, and these are true solid mounts. Weltmeister sells what they call a solid mount, but is actually a block of polyurethane (or some other clear redish color plastic like that used for bushings). Because the block is fairly large it probably has pretty good resistance to compression. This block goes where your steel block or tube is shown. I have a set in my spare parts collection, never used. Mike |
Lo-Fi Version | Time is now: 12th May 2024 - 08:10 PM |
