Brake Hardware, ...is it all needed? |
7TPorsh |
Mar 4 2009, 01:51 PM
I have gotten to the point of remounting the calipers with pads.
Are the metal plates that go inside between the piston and the pad needed? do they serve a purpose? Are they avaibale anywhere? Also the spring/clips...I assume those are required to open the pads off the rotor. Are new clips available? thx |
VaccaRabite |
Mar 4 2009, 02:23 PM
En Garde! Group: Admin Posts: 13,443 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
This question depends heavily on your desire to to stop consistantly. While in the Canyons of Glendale, Ca.
Zach |
Mar 4 2009, 02:31 PM
Resident German Group: Admin Posts: 41,638 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Are the metal plates that go inside between the piston and the pad needed? do they serve a purpose? Are they avaibale anywhere? (IMG:style_emoticons/default/confused24.gif) The only "Metal Plates" between the pads and the pistons should be permanently bonded to the pads ... (IMG:style_emoticons/default/huh.gif) Andy (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
type47 |
Mar 4 2009, 02:40 PM
Are the metal plates that go inside between the piston and the pad needed? do they serve a purpose? Are they avaibale anywhere? Also the spring/clips...I assume those are required to open the pads off the rotor. Are new clips available? thx I say the metal plates are needed. I think they are needed because they will keep the pistons at the correct 20 degree angle (see Haynes or factory workshop manual) that they are set upon installation into caliper. The 20 degree angle has something to do with pad wear or the retraction of the piston when you release the brake or something like that. I got the plates with a rebuild kit. As for the springs, I have the springs installed although a reputable local independent Porsche shop removes them from 911 brakes. |
southernmost914 |
Mar 4 2009, 02:47 PM
KEY WEST/HAVANA Tunnel Authority Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States |
The thin metal plates are piston indexing plates and keep the piston from spinning in its bore (front only). All part are avialable from vendors here.
Steve |
7TPorsh |
Mar 4 2009, 02:51 PM
this all sounds reasonable. Looks like a need a set of plates and clips. Vendors here?
7TPorsh |
Mar 4 2009, 02:52 PM
i'll try and takes some pics tonight.
Cupomeat |
Mar 4 2009, 03:06 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
It is my understanding that the angular locator plates are there to maintain the piston orientation and therefore provide uneven pressure on the pads giving more to the trailing edge of the pad.
I could be wrong. Keep them in place. If you have done the 320i conversion, they don't use them, BTW. |
Mar 4 2009, 03:37 PM
It is my understanding that the angular locator plates are there to maintain the piston orientation and therefore provide uneven pressure on the pads giving more to the trailing edge of the pad. That's what you get for dealing with 911 brakes for the last 8 years or so ... Totally forgot about those ... (IMG:style_emoticons/default/rolleyes.gif) Andy |
davep |
Mar 4 2009, 05:04 PM
I have a few sets of the angle plates available.
7TPorsh |
Mar 9 2009, 12:11 PM
So...where can i buy the spring clips? i have the plates.
7TPorsh |
Mar 9 2009, 12:24 PM
Are these the same as the early 911?
southernmost914 |
Mar 9 2009, 01:07 PM
So...where can i buy the spring clips? i have the plates. Try PMB Performance or AA for your part needs. (IMG:style_emoticons/default/biggrin.gif) Steve |
Lo-Fi Version | Time is now: 16th May 2024 - 03:15 AM |
