| crxnug |
Mar 5 2009, 03:35 PM
Member ![]() ![]() Group: Members Posts: 81 Joined: 20-December 07 From: ontario, canada Member No.: 8,489 |
Im looking at purchasing a donor front trunk from a 1971 to repair my 1973 2.0 that was cut out by PO, are these a exact match? or were there differences over the years
| Dr Evil |
Mar 5 2009, 04:08 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
In 73 there were reinforcements installed in front of where the tire sits. Other than that, nope.
| 9146BRUCE |
Mar 5 2009, 05:36 PM
Member ![]() ![]() Group: Members Posts: 57 Joined: 16-April 07 From: Northridge Calif. Member No.: 7,670 Region Association: Southern California
Hi since I just did this, I got a 73 front clip to fix my 70 front end and there is a difference. the 70 is smooth in the center from horn to horn on the 73 there are two indentations where the two rubber nipples on the bumpers fit.
Bruce |
| crxnug |
Mar 5 2009, 05:57 PM
this is the area im going to be replace, pic is not my car but shows what i plan on doing, does anyone have any pics showing the difference between the 70 and 73 lower trunk, i want to keep the car as factory looking as possible , thanks (IMG:http://imgs.inkfrog.com/pix/crxnug/108161062_eaf0298383.jpg)
| GeorgeRud |
Mar 5 2009, 09:15 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Looks like you're going to do a front pan replacement. I dont recall any differences in that area, so you should be fine. The replacement panels should also be available from AA or Restoration Design if you want to go with new metal.
| crxnug |
Mar 5 2009, 10:03 PM
i dont believe restoration design sells that piece, AA has a donor piece but its a bit pricey at $750 before s/h, so i found a somewhat rust free piece that im considering
| GeorgeRud |
Mar 5 2009, 11:09 PM
My bad, I was thinking of the 911 front floor pan that they do sell.
Lo-Fi Version | Time is now: 11th February 2026 - 03:27 PM |
