> Is a 1971 front trunk the same on a 73
crxnug
post Mar 5 2009, 03:35 PM
Im looking at purchasing a donor front trunk from a 1971 to repair my 1973 2.0 that was cut out by PO, are these a exact match? or were there differences over the years
Replies(1 - 6)
Dr Evil
post Mar 5 2009, 04:08 PM
Send me your transmission!
In 73 there were reinforcements installed in front of where the tire sits. Other than that, nope.
9146BRUCE
post Mar 5 2009, 05:36 PM
Hi since I just did this, I got a 73 front clip to fix my 70 front end and there is a difference. the 70 is smooth in the center from horn to horn on the 73 there are two indentations where the two rubber nipples on the bumpers fit.
Bruce
crxnug
post Mar 5 2009, 05:57 PM
this is the area im going to be replace, pic is not my car but shows what i plan on doing, does anyone have any pics showing the difference between the 70 and 73 lower trunk, i want to keep the car as factory looking as possible , thanks (IMG:http://imgs.inkfrog.com/pix/crxnug/108161062_eaf0298383.jpg)
GeorgeRud
post Mar 5 2009, 09:15 PM
Looks like you're going to do a front pan replacement. I dont recall any differences in that area, so you should be fine. The replacement panels should also be available from AA or Restoration Design if you want to go with new metal.
crxnug
post Mar 5 2009, 10:03 PM
i dont believe restoration design sells that piece, AA has a donor piece but its a bit pricey at $750 before s/h, so i found a somewhat rust free piece that im considering
GeorgeRud
post Mar 5 2009, 11:09 PM
My bad, I was thinking of the 911 front floor pan that they do sell.
- Lo-Fi Version Time is now: 23rd January 2026 - 01:49 PM
