Best place to get a rebuilt alternator? |
VaccaRabite |
Mar 10 2009, 06:07 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
My charging system isn't. Culpret could be the alternator. Where do I want to look to get a new one, or a good rebuilt one? Are the cheaper rebuilt ones on ebay that same as the ones from Pelican or AA? Is this a part I can get from NAPA up the street?
Zach |
StratPlayer |
Mar 10 2009, 06:15 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
I got a new one from a local FLAPS. All I had to do was shorten one of the bolts that sticks out the back of the alternator.
VaccaRabite |
Mar 10 2009, 06:17 PM
Like this on Ebay:
$59 ebay rebuilt alt by BNR Parts. Or this (with a voltage regulator included) $84, comes with a new voltage regulator. from Eagle Auto. Zach |
StratPlayer |
Mar 10 2009, 06:20 PM
I got mine at checker auto, I think it was around 65.00 new.
Joe Owensby |
Mar 10 2009, 10:31 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
I had mine rebuilt by a local guy who has a very good reputation for his work. I think it was about $50 or so. I know some of the Flaps rebuilders just replace what was broken, so a lot of the parts are old. The rebuilder I used was supposed to put in new bearings and diodes. JoeO
hcdmueller |
Mar 10 2009, 10:54 PM
????????????? Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England |
If you want a higher amp alternator you can buy a 912e alternator from FLAPS. Autozone had them for around $100. The only issue is your original 55amp pulley doesn't have a fan on it. I have been running mine for a while without the fan on the pulley and have no problems with it. You will have to buy a different rubber boot from the fan housing to the back as well. They sell them on the bus depot web site. Not for everybody. If you have the time to wait and need the extra amps this is a solution.
eg914 |
Mar 10 2009, 11:12 PM
Member Group: Members Posts: 319 Joined: 17-June 04 From: Elk Grove, CA Member No.: 2,223 Region Association: None |
I got my alternator at the local VW shop. Don't remember the price, as it was a couple years ago.
type47 |
Mar 11 2009, 08:09 AM
I was able to take my alternator to the local Advance Auto Parts and bench test the unit on their tester. Maybe you could verify the alternator at your FLAP unless you're sure it's bad. Should be able to test it at Autozone too.
VaccaRabite |
Mar 11 2009, 08:56 AM
Oh, thats a good idea. I'll test it before I replace it.
Zach |
Drums66 |
Mar 11 2009, 02:01 PM
Another very wise thing to do!
replace the alternator and voltage regulator together!! Reccomended (IMG:style_emoticons/default/bye1.gif) |
VaccaRabite |
Mar 11 2009, 04:09 PM
I got the alternator out this afternoon and swung by Advance to get it tested. Yeah, its dead.
Zach |
toon1 |
Mar 11 2009, 04:28 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
Did they have a special tester?
From what I have read in the past, a special setup is needed to test these alt's. |
VaccaRabite |
Mar 11 2009, 04:31 PM
The tester that they used has a special setting and wiring harness just for the these alternators, yeah.
Also, I bought the BRN Parts alternator off Ebay. They had really good feedback, and it was about 1/2 the cost of Pelican or AA. If I get burned, then so be it. Zach |
VaccaRabite |
Mar 11 2009, 04:32 PM
Oops. Double post. (IMG:style_emoticons/default/sad.gif)
VaccaRabite |
Mar 17 2009, 07:43 PM
Got my new alternator installed today. Light went out. Happy happy!
Zach |
jsayre914 |
Mar 17 2009, 07:45 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
VaccaRabite |
Mar 17 2009, 07:59 PM
Lo-Fi Version | Time is now: 16th May 2024 - 08:36 AM |
