| Jake Raby |
Apr 6 2010, 07:09 PM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
QUOTE I'm guessing it gets pretty, um, tense when Jake has some monster spooled up to major decibel level. Around 8-9K things get scary... Or when a 16:1 CR, 300HP N/A Pro Stock engine is screaming it is really intense! Type one or Type 4? Rich Neither.. Type NONE. An engine producing that much power has ZERO VW/ Porsche parts in it's composition. Two weeks in a row, two different cars laid down 501 and 507 RWHP on my chassis dyno, each being force fed with 30 PSI boost. Here is a sample of what thats like on the dyno. http://www.youtube.com/watch?v=EgwnJsCaHtw |
| r_towle |
Apr 6 2010, 07:27 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Cool, I was hoping it was a type one drag motor...
I am seeing more and more turbo type ones hitting over 300 and some are at 400 hp...interesting to see them run that much boost. Rich |
| Jake Raby |
Apr 6 2010, 08:13 PM
Cool, I was hoping it was a type one drag motor... I am seeing more and more turbo type ones hitting over 300 and some are at 400 hp...interesting to see them run that much boost. Rich Those engines also don't have many "Type 1 parts" in their composition either.. I've never built a Turbo engine that didn't make 300HP, if you can't make that much with boost, may as well give up. When an engine no longer uses a VW case or heads, its a Type NONE. |
| r_towle |
Apr 6 2010, 08:23 PM
Got ya....
I know its top secret....but can you share the displacement? And just for a question about turbos.. what is the most HP you have seen/built/heard of using a hidden system under the hood and not in the back seat...beetle of course Rich |
| Jake Raby |
Apr 6 2010, 08:33 PM
Got ya.... I know its top secret....but can you share the displacement? And just for a question about turbos.. what is the most HP you have seen/built/heard of using a hidden system under the hood and not in the back seat...beetle of course Rich Thats not top secret.. One engine is a 2332, the other is a 2387 The most I have made under the decklid was 230 RWHP, with ZERO mods to the body/ car- but that was 12 years ago from a little tiny 1776cc EFI boosted engine at 18 PSI boost... That engine and Turbo system is now for sale complete, I just freshened it up and gave it a better set of heads.. I bought the '57 Oval it was installed into from a good friend and have no use for the engine.. Here is one way to make 600+ flywheel HP.... Thos one made 510 RWHP last week at 28 PSI boost, no intercooler or water injection. I have 4 Turbo engines in work here now, from 1493cc Land Speed race engines to a 3.2 Liter, roller cammed twin plug monster TIV that uses a STOCK TIV case and OE heads. Should be good for 650 on pump gas. This post has been edited by Jake Raby: Apr 6 2010, 08:41 PM |
| r_towle |
Apr 6 2010, 08:52 PM
I am just not a fan of the large square box that hangs off the back of the latest generation of drag beetles..or the large open setup either.
What is the BEST that you think could be done in sleeper mode....I guess I will sacrifice the rear seat if needed....just want to retain the external appearance. Rich |
| RJMII |
Apr 6 2010, 10:13 PM
Jim McIntosh ![]() ![]() ![]() ![]() Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
I opened this thread half-way expecting to see an engine spraying green stuff all over the place. (IMG:style_emoticons/default/lol-2.gif)
| Jake Raby |
Apr 6 2010, 10:14 PM
I am just not a fan of the large square box that hangs off the back of the latest generation of drag beetles..or the large open setup either. What is the BEST that you think could be done in sleeper mode....I guess I will sacrifice the rear seat if needed....just want to retain the external appearance. Rich I think 300 would be pushing it, BUT most of the time you can't put that much to the ground anyway. I have a really bad ass tranny to go with that Turbo engine from my Oval, it has drag gearing already.. Its so bad ass that it cost 5K to build 12 years ago! |
Lo-Fi Version | Time is now: 9th June 2026 - 11:59 PM |
