MSD Ignition 6A USE Adapter 8920, wich adapter so use 8910 or 8920 |
jc914 |
Mar 14 2009, 02:46 PM
Member Group: Members Posts: 289 Joined: 15-September 08 From: Miami, Florida Member No.: 9,548 Region Association: South East States |
I just Installed a MSD 6a WHAT A difference 100% (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/biggrin.gif)
Now my tach will not work. I have searched the forum for what I need to do. I have found no real answer some use the MSD adapter 8910 others the 8920. I have a 73 fuel injected 2.0 with pertronix. According to MSD the 914 (mine) the tach wire used to go to the Negative of the bosch coil and it is called a Voltage Trigger and says to use the 8910. I have read others using the 8920 with no problem. below are two diagrams I found. Which is the correct one to use 8920 (IMG:http://i176.photobucket.com/albums/w177/JCD404/tach.jpg) 8910 (IMG:http://i176.photobucket.com/albums/w177/JCD404/tach3.jpg) THANKS I found this on line about the 8920 http://www.msdignition.com/forum/archive/i...php?t-8649.html |
Kirmizi |
Mar 15 2009, 11:33 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Ditto what Aaron said.
I've got a Unilite and MSD 6a running with no tach adapter. Do a search for MSD installation, or tach adapter; and you should be able to find the wiring setup diagram. Fact is, I've got a brand new un-opened 8910 I bought just in case, and never needed it. Mike |
Lo-Fi Version | Time is now: 21st May 2024 - 09:47 AM |
