END PLAY HELP NEEDED, OK, I think I got it fixed! |
stephenaki |
Mar 15 2009, 10:14 AM
Can I get this one dad?? Group: Members Posts: 1,183 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None |
OK, I finally picked up a dial indicator. So, I pulled the flywheel off and, as I expected, the guys that checked endplay for me only put one shim in.
So, I put two in per the book, torqued it down and dang! I have no play and I can't even turn the flywheel! So, I pull one out and leave one in, .20mm reading. My guess at this point is I need a whole new set of shims. I did some measurements and here is what I have. Enplay with no shims - .49mm shim 1 - .25 shim 2 - .31 shim 3 - .35 So my assumption at this point is that I need 3 shims that will not exceed .42 in total measurement. Is it safe to assume that the grease will also alter the measurement so I should look at getting 3 shims at .10, .15 and .15? This would give me an estimated measurement between .07 and .09 with grease. Thoughts? |
Jake Raby |
Mar 20 2009, 05:10 PM
I see the issue... Or at least I believe I do, based on these pics.
Get me closer pics of the #3 main bearing from different angles.. (the one behind the crank gear) Also see if there are any signs that the bearing face has contacted the gears. Do the same with bearing #4, the small one.. Pull the crank out and see if the bearings are damaged. That assembly lube looks like Moly grease.. please tell me it isn't... |
stephenaki |
Mar 21 2009, 11:08 AM
Get me closer pics of the #3 main bearing from different angles.. (the one behind the crank gear) Also see if there are any signs that the bearing face has contacted the gears. Do the same with bearing #4, the small one.. Pull the crank out and see if the bearings are damaged. Per your request... I didn't see any indication that the bearings contacted the gears, I took several pictures and spun the bearings around so you can see all sides of it. I also took a picture of the case where the #4 bearing sits; it looks as if some metal was chipped off the surface. I am not familiar enough with this type of motor to know if this is an issue or not. Let me know if you want me to take this to PM or would prefer this venue so all can learn from my issues. (IMG:http://i273.photobucket.com/albums/jj217/stephenaki/Porsche%20914/CIMG2985.jpg) (IMG:http://i273.photobucket.com/albums/jj217/stephenaki/Porsche%20914/CIMG2986.jpg) (IMG:http://i273.photobucket.com/albums/jj217/stephenaki/Porsche%20914/CIMG2987.jpg) (IMG:http://i273.photobucket.com/albums/jj217/stephenaki/Porsche%20914/CIMG2988.jpg) (IMG:http://i273.photobucket.com/albums/jj217/stephenaki/Porsche%20914/CIMG2989.jpg) (IMG:http://i273.photobucket.com/albums/jj217/stephenaki/Porsche%20914/CIMG2990.jpg) (IMG:http://i273.photobucket.com/albums/jj217/stephenaki/Porsche%20914/CIMG2991.jpg) (IMG:http://i273.photobucket.com/albums/jj217/stephenaki/Porsche%20914/CIMG2992.jpg) (IMG:http://i273.photobucket.com/albums/jj217/stephenaki/Porsche%20914/CIMG2993.jpg) |
Jake Raby |
Mar 21 2009, 12:52 PM
OK, nothing jumped out at me in the pics.
Drop the assembly back into the case half and align the dowels in the mains. Stick on the flywheel and use a feeler gauge to measure the end play present with no shims. Pull the assembly fully back in the case (toward the flywheel and take some pics of each bearing... We will find this. |
jcd914 |
Mar 21 2009, 07:26 PM
It might be that it has been too long since I had a T4 engine apart and I don't remember well but...
In the first set of pictures you post it looks like the #3 bearing is not positioned correctly. It look like the bearing is off set closer to the crank gear than it should be and I expected the oil hole to be positioned up higher. I would expect the bearing to be centered on the bearing web of the case. The only way the bearing could be out of position is if there is no locating dowel pin for #3 bearing. In the second set of pictures I would expect to see at least some minor scuffs or scrapes from the dowel pin on the #3 bearing near the locating hole and I don't see any. It also looks like the gear side of the #3 bearing is shiny like it had been rubbed by the gear. Do you have a picture of the dowel pin in place for #3 bearing? Good luck. Jim |
stephenaki |
Mar 30 2009, 09:53 AM
It might be that it has been too long since I had a T4 engine apart and I don't remember well but... The only way the bearing could be out of position is if there is no locating dowel pin for #3 bearing. Do you have a picture of the dowel pin in place for #3 bearing? Good luck. Jim I finally got around to re-checking and doing what Jake wanted and your right Jim, there is no dowel pin in the #3 bearing position! Definitely an issue. Now Jake, per your instructions; dropped the crank back in, attached flywheel; slid all the way forward and checked with feeler gauges. I was able to combine a .635mm/.025" and .508mm/.020" feeler gauge and get it between the flywheel and crank. No slop, tight fit that enabled me to push them lightly into place and pull them out with minimum effort. Combined measurement of 1.14mm or .045mm. So this is obviously good however, no dowel pin in #3 is not good; would this affect endplay? Truth be told, I am really glad I tore the motor back down again. Thoughts? Do you by chance have any extra dowel pins? And while your at it, the rocker arm nuts for the valve train are M7 correct? I am missing a nut for one of the rocker arms and I can't find any M7 nuts here. Do you have any? Here are the pictures you requested; I forgot to get a picture of the #4 bearing with the crank slid all the way forward. If you need me to get one let me know. (IMG:http://i273.photobucket.com/albums/jj217/stephenaki/Porsche%20914/CIMG3007.jpg) (IMG:http://i273.photobucket.com/albums/jj217/stephenaki/Porsche%20914/CIMG3009.jpg) (IMG:http://i273.photobucket.com/albums/jj217/stephenaki/Porsche%20914/CIMG3010.jpg) |
jcd914 |
Mar 30 2009, 03:33 PM
no dowel pin in #3 is not good; would this affect endplay? It could affect the end play if the bearing was off center enough that the crank gear was contacting the #3 bearing before the crank contacted the thrust surface on the #1 bearing. Essentially #3 would be serving as a thrust bearing limiting the end play. I don't know if I have a bearing dowel pin but I will look (I should, had enough engines apart over the years). I can't comment on the pictures, at work our Internet filters block all photobucket links (lots of sites are blocked). It is a bit of an irritation to me when images are linked but I can see them from home. Take care Jim |
stephenaki |
Apr 15 2009, 05:29 AM
WOOHOO! BACK IN BUSINESS! Got some dowel pins the other day from Travis at Type IV and put the missing one in last night. Installed a .24 and .30 mm shim and torqued the flywheel down.
Took out the dial gauge and...wow, that made a difference! Measurement with 2 shims came in at .49mm. I have one shim left that measures in at .34 which, once installed would give me .15 which is still .02 out of tolerance. So, my thoughts are install the .24 and .34 and then pick up a .36mm shim for the third shim which will put me into the .09mm range which is well within tolerance. I have a local source here that I can get the shims and will see if I can pick them up this week. Saturday, after recovering from Fruehlings fest (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beer3.gif) , I will clean up the motor and begin re-assembly again. The goal is to get the motor completely put together by the end of the weekend. Hmm, that sounds familiar, maybe this time I will 'git r done!' (IMG:style_emoticons/default/piratenanner.gif) |
stephenaki |
Apr 23 2009, 09:46 AM
OK, talked to Travis at Type IV and sent him an email, here is what I sent, anyone else have any ideas what could be causing this?
Installed the dowel pin in #3bearing position and got the crank in all lined up with all dowel pins and double checked. Put in two shims and got too much endplay as opposed to the too little that I had a problem with due to the missing dowel pin. Took out all shims, re-torqued the flywheel down and spun it to TDC, then BDC then put TDC mark on left bank and right bank sides and measured here is what I got. All measurements are in millimeters. TDC - .45 (applying pressure to plate and holding in place) .32 (no pressure applied to plate, basically pushed it in then released the pressure) BDC - .63 with pressure .49 no pressure TDC mark facing left bank and then right bank were the same, 1.11 mm. The crankcase is assembled and torqued, cylinders, pistons and heads are also assembled on the case and torqued to specs. Nothing else is assembled or installed. |
gopack |
Apr 23 2009, 10:16 AM
CHEESEHEAD in CA, MARK Group: Members Posts: 744 Joined: 7-August 04 From: Folsom, CA Member No.: 2,472 Region Association: Northern California |
I just wanted to say that although I don't yet have the intestinal fortitude to tear into an engine, I am always amazed to see how far Jake will go to help total strangers with his valuable knowledge and time!
THANKS JAKE! These kind of threads are great learning experiences for the lookie-loos, as well as the hands on guys! |
stephenaki |
Apr 25 2009, 01:18 AM
Unfortunately, Jake was heading to a race so it may be a bit. I was thinking about the issue and trying to find some info on too much endplay on the web. A couple of VW sites mentioned spun bearings, another site mentioned dowel pin wallowing in the case hole.
I don't think the bearings are spun but the #3 dowel pin bearing did fit pretty sloppy; would this effect endplay and, more importantly, does this mean the case is now toast and I need a new one? |
JFJ914 |
Apr 25 2009, 01:57 PM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
stephenaki |
Apr 27 2009, 09:01 AM
Put in two shims and got too much endplay You need three shims, not 2! The shim at the flywheel spins at crank speed, the one at the bearing doesn't spin and the one in the middle acts as a bearing so that can happen. Good luck. John, Yes, I know this however, you use 2 shims to determine what size the 3rd shim should be. Based on measurements the difference was too large to be made up by the largest shim made. On a positive note, I will pick up a complete case and all the internals from Boxter motors tomorrow as he had an unused 1.7 case in his other warehouse. I will have to strip it down and pull the internals but I will have a new case to check endplay with. I am hoping the 'sloppy' dowel pin is the issue and this new/used case doesn't have the slop and solves the problem. Wish me luck. (IMG:style_emoticons/default/biggrin.gif) |
stephenaki |
May 2 2009, 06:44 AM
OK, I finally think I got this thing beat! I picked up a new case from Boxter, got it cleaned up and prepped for the internals. I tore down the other case and pulled the internals out yesterday then took a break from work (yes I'm working today and all friggin weekend!) and shot home to put the internals in the new case.
Pulled the crank and cam, prepped the new case, popped in new dowel pins, lined everything up and marked it when I dropped in the assembly, put the cam shaft in then sealed up the case and popped on 2 shims .24 and .32mm respectively. Measured endplay and came up with .46-.49 all the way around. Good to go, took off the flywheel and popped in three shims; .32, .34 and .34mm. Re-torque the flywheel and I came up with .17 all the way around. Doing the math, if I pop in 3 shims at .36mm a piece that should put my endplay at about .09 which is well within tolerance. So the slop in the #3 bearing dowel pin was the issue. I will take the case halves to a local machinest on Monday and have him clean it up as well as put in a new dipstick tube as this case had a broken tube. I did some searches on the forum about it but the case has sat so long I didn't want to screw around and make it worse. I will let a professional fix this minor issue so it doesn't become a major one. I will probably take the old case to him and have him see if he can pull the good tube on the old case and use it. If I can get everything back by Wednesday then I can have the motor put back together and over to Christoph before Saturday which means it will be ready for me when I return from my ride up to Scotland on the 10th. This would make me and the wife happy. Cross your fingers on this one! (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 11:58 AM |
