914-V8 Radiator Size and Angle Issues/Questions, Calling all 914 v8 Guys |
wallys914 |
Mar 18 2009, 05:26 PM
In life you don't get what you want, you get what you negoia Group: Members Posts: 190 Joined: 10-October 08 From: Garden Grove, Member No.: 9,631 Region Association: Southern California |
Im trying to Figure out if an extra radiator i have will work for my V8 conversion. It is at an 35-45 degree angle to fit under the hood, is that to much?
It's a 30x18 dual core, I thought it would fit but guess not. What size are the renegade ones? They look raked out when the are installed as well. Thanks. |
Bruce Hinds |
Mar 18 2009, 08:08 PM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
I looked at this earlier and was curious to see what was going to come back! I don't think angle has much to do with anything. You need a certain area of cooling tubing and you need to get air through it.
The most important factor( if you have a big enough radiator) is getting the air out. You can have a mack truck rad. but if there is no where for the air to go it ain't gonna cool. That being said, inlet size isn't critical, flow is. Make sure you have enough "draw" on the flow. In the old days when they first came out with a 4 row, it didn't make that much difference if you can't get the air through. Supplemental fans made the difference! Here again though, in the limited space, even fans may not get the air out. Since then, they've come out with bigger tubes(more area) and gotten the same or better cooling with just 2 rows. The guys at renegade really have the ticket, they've done this so often, and come up with a great combination. I've done okay all these years with just a regular camaro unit, but don't waste your time trying to make some junk work, just get their kit. It's well worth the $ and will save you countless hours and many sleepless nights. B |
computers4kids |
Mar 18 2009, 09:29 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
The guys at renegade really have the ticket, they've done this so often, and come up with a great combination. Here's the Renegade setup,(IMG:http://www.914world.com/bbs2/uploads/post-4253-1215527764.jpg) |
byndbad914 |
Mar 18 2009, 09:38 PM
shoehorn and some butter - it fits Group: Members Posts: 1,547 Joined: 23-January 06 From: Broomfield, CO Member No.: 5,463 Region Association: None |
18x30 dual core is a pretty standard rad size for NASCAR stuff - I am assuming it is 1" capillary like a typical alum dual core double pass made in the past decade. Assuming all of that, you have enough radiator.
For your specific question, you can lay that radiator nearly flat and be okay - you should see the angles in some Ultima kits and so forth. Does it have a radiator cap/fill neck on it, or does the rad require a separate fill tank? My point is if you lay it over, you want to have a separate fill tank that feeds the radiator. Here is my 16x28 dual pass, two core NASCAR style radiator and you can see it is laid over pretty far. Also note the Moroso fill tank. |
JRust |
Mar 18 2009, 09:42 PM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Renegades setup was the best money I have spent on my v8 to date. I highly recommend it & them (IMG:style_emoticons/default/biggrin.gif) . I really looked for quite a while but by the time you get all the pieces. You are going to spend close to that if not more. It is everything you need in one package. You can do it cheaper if you are resourceful. I tried or at least looked before spending the money. After my issues at last years WCR (IMG:style_emoticons/default/headbang.gif) . Believe me I was wishing I had just ponied up the dough then (IMG:style_emoticons/default/dry.gif)
byndbad914 |
Mar 18 2009, 09:52 PM
Renegade's setup is $1K. I have around $600 in my setup with 525HP that I beat the hell out of on the track and don't over heat. If he already has the radiator and it appears to be more than sufficient, he is most of the way there IMHO.
charliew |
Mar 18 2009, 09:59 PM
I have a dual one inch tube aluminum and a wrx radiator that are the same outside size but the custom radiator is thicker. They are neither crossflow. Either one will need to be angled to fit. Neither is as thick as the renegade setup but my hp requirements are also lower. The wrx radiator works on 375 hp subys and thats all I will need. The fiero uses a angled design and sbc's have been put in them forever. The trick is to get the low pressure on the back side and not have any recirculation of the hot air.
The fiero configuration looks a lot like byndbad's setup. Except it has a front trunk and the gas tank goes down the center tunnel. It looks like with renegades setup you lose enough of the trunk to say you don't have one so that means just concentrate on cooling and not try to save some trunk. |
TC 914-8 |
Mar 18 2009, 10:11 PM
Senior Member Group: Members Posts: 808 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest |
All good stuff from the guys above. I have a rod Simpson radiator which is close to the Renegade set up. Bruce is on the right track with air flow. I never had cooling problems but I did fab up a schroud that sucks air thru the complete surface. Also make sure you have a air dam of sorts to build up a "high Pressure" in front of the radiator when driving and a decient exit ait path to create a "low pressure" behind the radiator. and you should be free of cooling problems. Last but not least, elimiinate any air in the water flow, have a bleed port at the highest point in the sustem. hope this helps, Tony |
TC 914-8 |
Mar 18 2009, 10:12 PM
JRust |
Renegade's setup is $1K. I have around $600 in my setup with 525HP that I beat the hell out of on the track and don't over heat. If he already has the radiator and it appears to be more than sufficient, he is most of the way there IMHO. Your right he does have a rad alllready. I was thinking he was looking. I originally went with what my car came with. Didn't work well for me. So I started looking at other options. I'm not one to fab up a system. So my search concentrated on radiators with dual fans, relay & a shroud. |
TC 914-8 |
Mar 18 2009, 10:15 PM
All good stuff from the guys above. I have a rod Simpson radiator which is close to the Renegade set up. Bruce is on the right track with air flow. I never had cooling problems but I did fab up a schroud that sucks air thru the complete surface. Also make sure you have a air dam of sorts to build up a "high Pressure" in front of the radiator when driving and a decient exit ait path to create a "low pressure" behind the radiator. and you should be free of cooling problems. Last but not least, elimiinate any air in the water flow, have a bleed port at the highest point in the system. hope this helps, Tony |
wallys914 |
Mar 19 2009, 02:58 AM
Thank you all, I can go back to sleep happy.
To answer Byndbad914's question, it is 1.5" thick and it does have a Cap/Filler neck on it. I guess that was where my concern was with the Angle. |
charliew |
Mar 19 2009, 09:31 AM
1.5 is not very thick compared to renegades. I will depend on how much hp the motor makes. I would try to do the install keeping in mind that a thicker radiator might be needed later. Also check to see if a high performance radiator the same size is available if it's needed or you will be making new shrouds and everything all over again. Most average sbc's making about 275 hp use a 19 x 28-30 two row copper radiator. The replacement radiator for my suburban with a 350 is a aluminum core/ plastic tank two row and it's about 19x 30. The aluminum core really cools a lot better but the plastic tanks are questionable if the radiator is not mounted really well. Think about it hard as I really hate to need to do something over just because I tried to save maybe 200.00. There are many new all aluminum radiators on the market for about 250.00
You might just wall off the sides out at the light walls and build the radiator support to hold the radiator you have and maybe all you would need to change is the support and the fan shroud for a new radiator if it is needed. |
andys |
Mar 19 2009, 03:52 PM
Though yet to be tested, I am using an AFCO dual pass, dual core ASA racing radiator, 15" x 27 1/2" with cap delete, bleed port, and sensor bung. It was $229 directly from AFCO a couple of years ago. I would make sure you pay attention to your ducting, as you want to avoid having the air flowing around the radiator rather than through it.
Andys |
wallys914 |
Mar 19 2009, 05:23 PM
Well Considering I got the Aluminum Radiator from a friend and the fact that I had a set of 14" fans already and Im only invested 35$ into coolong so far. I dont think I would regret it if I had to do it over! PITA yes, but I figured that with the aluminum sheet for ducting all the ish I have already I should be good for a clean radiator install for just under 200$ and that beats the hell out of a G for Renegade's.
Just my Brain Change.... Off the subject can some one post a pic of the Renegade fill tank in the engine compartment, I have read through every V8 Thread and no one has a clear defined pic of that setup. Thanks again guys.... And byndbad914 your Car was built by Baja Shop Huh? I saw it there before... |
computers4kids |
Mar 19 2009, 06:36 PM
Off the subject can some one post a pic of the Renegade fill tank in the engine compartment, . Renegade (IMG:http://www.914world.com/bbs2/uploads/post-4253-1212388992.gif) |
byndbad914 |
Mar 19 2009, 06:54 PM
And byndbad914 your Car was built by Baja Shop Huh? I saw it there before... yep, I see you are in Orange - I had it built there in '06 before they moved out near Corona! I have since moved as well in '07 to CO. You can run a rad with a cap on it, just put a higher pressure one on than on the fill tank. Being alum you can simply weld a bung in to get the flow back into the tank. The fill tank can just tee into the low pressure side of the system. Here is a shot of mine after everything is installed. you can see the return comes in the top pass side, flows across and then there is a return loop back to the tank where some goes back (the blue hose to the top of the fill tank). out of the bott of the fill tank you can see it T's into the low pressure suction side out of the radiator (goes between the rad and the water pump suction side). It is a bit hard to see the brass fitting but it goes into the dull alum feed pipe v. the shiny return pipe. Works perfect. the white plastic tank is just for overflow should that happen. Here is what you would have seen at AJs - this was right after I picked it up I just previewed and realized the two most important tools are in that shot - a hammer and a crescent wrench (IMG:style_emoticons/default/lol-2.gif) |
charliew |
Mar 19 2009, 11:23 PM
On the fill tank it looks like it is bypassing the radiator from the top to the waterpump suction side.
marks914 |
Mar 20 2009, 12:57 PM
Senior Member Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
The angle should be OK. Desert Hybrids runs an angled setup in arizona, so it should work. Just make sure that there is sufficient airflow in and out, and that the front is shrouded and sealed. Also make sure that the hot air is not recirculated into the front when sitting still.
I had this setup made for me ata local radiator shop for $275.00 and have never had the car over 190F Mark (IMG:http://inlinethumb51.webshots.com/5682/2033403670057582025S600x600Q85.jpg) |
BIGKAT_83 |
Mar 20 2009, 04:01 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Not a good picture but this is a Double pass 16X28 Ron Davis with 2 16" Spal fans. I also have a SPAL pwm fan controller, It has programmable presets for the fans. You start with one fan at 1/2 speed and fan speed increases with tempeture. When the fan reaches full speed and the tempeture increases 10 degree more the second fan comes on at full speed also.
Bob |
Lo-Fi Version | Time is now: 2nd May 2024 - 12:24 PM |
