Decoke an engine |
Decoke an engine |
davep |
Feb 25 2004, 01:40 PM
914 Historian Group: Benefactors Posts: 5,141 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Years ago when I worked in a dealership we used a fluid to burn the carbon from the combustion chambers. The mechanic would take the car out into the country, then hook up a line from the can to a vacuum port on the intake side, and go for a little run. The smoke would just billow out until the can ran dry. It apparently did a good job. Does anyone recall this product that I can use to burn some carbon out?
DaveP |
Mueller |
Feb 25 2004, 01:46 PM
water???
d7n7master |
Feb 25 2004, 01:47 PM
Gary# Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 |
I've seen it done with plain 'ol water poured out of a Coca-Cola Bottle into the carb while keeping the rev's up. (by a mechanic at a Arco station I worked at as a kid...) (IMG:style_emoticons/default/ohmy.gif)
JWest |
Feb 25 2004, 01:49 PM
GM Top Engine Cleaner - get it at your GM Dealer.
Jake Raby |
I have used coca cola to do it before....
I have even had some low power Turbine engines like a 2liter of coke ran through them..... The deposits just pour out of the exhaust flange. |
redtiny914 |
Feb 25 2004, 01:55 PM
Newbie Group: Members Posts: 14 Joined: 24-February 04 From: St Louis MO Member No.: 1,711 |
He is right about the Coca Cola....I believe it works because of the acid in the coke.
I am a nurse and we use coke to clean out G tubes...same concept though...just using it on people instead of cars in my line of work..... (IMG:style_emoticons/default/smile.gif) |
Jake Raby |
Feb 25 2004, 02:16 PM
Using orange Kool-aid to clean the toilets onboard ship was the most amazing one I have seen! Cleaning a pisser that sees 1000 people a day is a true chalenge for anything... Kool aid is the best! Just ask any Squid and they'll say the same thing!
lagunero |
Feb 25 2004, 03:02 PM
Donkey Member Group: Benefactors Posts: 1,042 Joined: 8-January 04 From: orange county,ca Member No.: 1,531 |
Swepco has a product and the instructions are very much the same as you describe. I think it's the Valve Cleaner additive.
JmuRiz |
Feb 25 2004, 03:10 PM
914 Guru Group: Members Posts: 5,425 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
So has anyone done this...or have they just heard of doing it (aside from Jake)? And does it really work? Might help a tired old car/bike work a little better. My bike had a ton of buildup in the header when I repainted it (IMG:style_emoticons/default/blink.gif)
MattR |
Feb 25 2004, 05:04 PM
Coke should add an addendum to their label for instructions...
airsix |
Feb 25 2004, 05:38 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
Whatever wonder concoction you guys put down your intakes make sure it's in small enough quantity that you don't get a hydraulic lock and bust the motor. I'ts probably easier than it sounds (to lock & bust the motor). I would replace the word "pour" with "mist" in all of the above. I have seen a motor get hydraulic locked on a surprisingly small volume of fluid.
-Ben M. Disclaimer - I don't have any experience doing this and am neither recommending nor discouraging against it. |
steve@ottosvenice.com |
Feb 25 2004, 06:32 PM
Member Group: Members Posts: 214 Joined: 9-November 03 Member No.: 1,324 |
need4speed |
Feb 25 2004, 07:13 PM
Member Group: Members Posts: 339 Joined: 11-April 03 From: Arroyo Grande, CA Member No.: 564 |
I think Coke would be a VERY bad idea.
Ever have some smartass dump sugar in your gas tank? Know how much sugar there is in Coke? Maybe diet coke. . . Or better still, a fluid specifically made for the task. |
DuckRyder |
Feb 25 2004, 07:17 PM
Avatars Mode: OFF because of the recalcitrant few. Group: Benefactors Posts: 767 Joined: 8-January 03 From: Georgia Member No.: 110 |
Lubro Moly Ventil Sauber, GM Top engine clean, ATF all work.
As was stated, carefull how much or you can bend rods............ |
Lo-Fi Version | Time is now: 11th May 2024 - 11:35 PM |
