which stock Brake pads?, and where to get them? |
tat2dphreak |
Feb 25 2004, 03:27 PM
ok, there has been a lot of talk lately about using a stock caliper setup with aggressive pads in lieu of a BMW upgrade for street applications... I had a BMW upgrade in my old car(2002 brakes) but never really had a choice either... the old calipers were TOAST! since the calipers on the Red car are in (semmingly) good shape.. I want to try the other method...
SO... which Brake pads are best for aggressive street (street driven like it's a time trial (IMG:style_emoticons/default/wink.gif) ) for under $100(ish) per axle... I would like to do all 4 wheels for under $200.. .I already have new bearings(front) and new rotors(all 4) and a 19mm M/C... and a "T" if needed(?) also, where can I get the pads at a good price online? I went to several sites today that had racing/street pads... but didn't seem to know exactly what was right for my car... one even listed all 914 pads as the same... front or rear, regardless of year (IMG:style_emoticons/default/blink.gif) SCARY! if there is not an online source, then where? thanks!! |
seanery |
Feb 25 2004, 03:29 PM
I just received my Porterfield R4S pads. I got them from Livermore Performance. $58/axle. The R4 is a track pad and the R4S is the street version. As soon as my hubs and rotors come in I'll tell you how they work.
RocknRollFrenzy |
Feb 25 2004, 06:01 PM
Member Group: Members Posts: 94 Joined: 3-November 03 From: Santa Cruz, CA Member No.: 1,305 |
QUOTE(tat2dphreak @ Feb 25 2004, 01:27 PM) ... one even listed all 914 pads as the same... front or rear, regardless of year (IMG:style_emoticons/default/blink.gif) SCARY! if there is not an online source, then where? thanks!! apparently some places have you use the same pads for both front and rear, but you have to open up one of the holes to fit the retaining pins on the set that you put on the rear. can't say if this is a good idea or not, but it never really seemed like the best way to go to me. incidentally, i'll be in need of some new pads fairly soon as well, so start posting folks. the more input the better. |
Aaron Cox |
Feb 25 2004, 06:12 PM
(IMG:style_emoticons/default/smile.gif) ive been using jurid pads. they seem to do okay
tat2dphreak |
Feb 25 2004, 07:19 PM
QUOTE(seanery @ Feb 25 2004, 03:29 PM) I just received my Porterfield R4S pads. I got them from Livermore Performance. $58/axle. The R4 is a track pad and the R4S is the street version. As soon as my hubs and rotors come in I'll tell you how they work. that seems like a a good deal! let me know how they work, I want to order soon... QUOTE ive been using jurid pads. they seem to do okay are they a softer/more OE type of pad? or more of an aggressive? which model? |
DuckRyder |
Feb 25 2004, 07:29 PM
Avatars Mode: OFF because of the recalcitrant few. Group: Benefactors Posts: 767 Joined: 8-January 03 From: Georgia Member No.: 110 |
I like hawks (HPS) on all my stuff.
Performance carrys them if you can stand to deal with them. |
seanery |
Feb 25 2004, 07:38 PM
I've used Hawks on my other cars in the past. They don't have a HPS rear pad available for the teener.
I like them, but they can squeak a bit when cold. |
steve@ottosvenice.com |
Feb 25 2004, 07:48 PM
Member Group: Members Posts: 214 Joined: 9-November 03 Member No.: 1,324 |
MINTEX C-TECH Brake Pad Set
Sport M1144 Suitable for Club, Rally, High-Performance Street Vehicles and Autocross. PAGID S (RS 4-2-1) Brake Pad Set Sport RS 4-2-1 (Blue) PAGID RACING Brake Pad Set Sport RS 4-2-1 (Blue) Brake Pad Set Racing RS 4-4 (Orange) This has a higher fade resistance and a higher average friction value than the RS 4-2. For the Rear MINTEX C-TECH M 1144 These may be what you looking for? Steve |
Matt Romanowski |
Feb 25 2004, 08:48 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
On the street, your never going to get the same abuse as at the track. But, I'm like you and run a "race" pad all the time. I have tried lots of pads, but I'm using Porterfield R4 right now and am extremely happy. With my 2270 and stock calipers all around, I have over 30 sessions on the pads and they are just needing replacement. This compares with ~6 for a set of Ferodos.
Matt |
tat2dphreak |
Feb 26 2004, 09:48 AM
I think I am going to give those porterfields (R4S) a shot...
now... should I replace the valve w/ a "T"? I almost want to just to keep from bleeding the damn valve... such a PITA! is this a bad idea? I replaced it in my other car, b/c of the BMW brakes... |
RocknRollFrenzy |
Feb 26 2004, 12:38 PM
if you're using the stock brakes, i'd keep the valve. its there for a reason, annoying as it may be.
brant |
Feb 26 2004, 12:49 PM
I have portefields in a focus right now and a suburban before that... and ginter had the street compound in his teener that he sold...
I really do like them on the street... BUT THEY ARE SQUEEKEY........ brant |
tat2dphreak |
Feb 26 2004, 12:53 PM
QUOTE(brant @ Feb 26 2004, 12:49 PM) I have portefields in a focus right now and a suburban before that... and ginter had the street compound in his teener that he sold... I really do like them on the street... BUT THEY ARE SQUEEKEY........ brant (IMG:style_emoticons/default/unsure.gif) if the squeak is that bad, can anything be done about it? that makes me second guess... |
seanery |
Feb 26 2004, 12:58 PM
my hawks squeaked when cold, but wouldn't when they were warmed up a bit.
brant |
Feb 26 2004, 01:23 PM
yeah.. I agree with sean..
they aren't so bad after they have been driven a couple of miles around town with a few stop signs worth of heat.... I think stock type pads are good for squeek.. Also, I don't know if EBC makes a teener pad, but I've run them in the focus too and they didn't squeek as bad as the R4S pads... brant |
seanery |
Feb 26 2004, 01:27 PM
I put Hawk HPS in the Range Rover (big & heavy) man, when they were cold they were LOUD! and didn't stop too well.
tat2dphreak |
Feb 26 2004, 01:28 PM
OK, that doesn't bother me, I expected squeak before warm up... I was afraid you meant as long as you drive... (IMG:style_emoticons/default/wacko.gif)
that would drive me NUTS!... ok,ok,ok already too late, but stiill! |
Gint |
Feb 26 2004, 07:57 PM
Mike Ginter Group: Admin Posts: 16,070 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
QUOTE I have portefields in a focus right now and a suburban before that... and ginter had the street compound in his teener that he sold... I really do like them on the street... BUT THEY ARE SQUEEKEY........ Unless you're on the track... quiet as a mouse then. (IMG:style_emoticons/default/wink.gif) They did drive me nuts on the street. But man did that car stop. |
Lo-Fi Version | Time is now: 11th May 2024 - 01:09 AM |
