> cooling system
stecz
post Feb 25 2004, 06:33 PM
My 914, if I drive it awhile, especially on the highway, will slowly get hotter and hotter. I was wondering what the easiest way to check if the flaps/thermostat were working. I can get to the top of the linkage, but does anyone know of a good way to prop it open? I was going to prop it open, go on a long drive and then see if the engine ran cooler...
Any ideas for testing it?
stecz   cooling system   Feb 25 2004, 06:33 PM
Mike D.   The bellows pulls the flaps closed when cold. Ther...   Feb 25 2004, 06:41 PM
McMark   :agree: If you can push down on the tab where th...   Feb 25 2004, 07:15 PM
stecz   Darn, it looks like the flaps are already in the f...   Feb 25 2004, 09:37 PM
Brad Roberts   Take brake cleaner and blow it UP at the bottom of...   Feb 25 2004, 10:02 PM
Aaron Cox   i wouldnt think a trunk mounted oil cooler would b...   Feb 25 2004, 10:32 PM
Brad Roberts   Under trunk mounted oil coolers are worthless. I h...   Feb 25 2004, 10:56 PM
Jake Raby   The wonderful gauge that Porsche used in the car w...   Feb 25 2004, 11:10 PM
stecz   Sounds like what I need to do is: - Adjust the va...   Feb 26 2004, 12:10 PM
stecz   What are some recommendations on CHT gauges and ho...   Feb 26 2004, 12:15 PM
stecz   ok... last post... I did a bunch of research on o...   Feb 26 2004, 02:20 PM
StratPlayer   I have a front mounted oil cooler with an LE Spoil...   Feb 26 2004, 02:35 PM
stecz   Some pictures would be great...   Feb 26 2004, 02:38 PM
StratPlayer   Heres an old thread with a shot of my cooler mount...   Feb 26 2004, 02:44 PM
Mike D.   Guy's, I have been driving a stock FI 2.0 with...   Feb 26 2004, 02:56 PM
airsix   This thread of mine shows what I found when I pull...   Feb 26 2004, 03:11 PM
fraggle00   If you've never pulled the motor, pull it, rem...   Feb 26 2004, 09:44 PM
campbellcj   As you know, JW (Otto) was pretty strongly opposed...   Feb 26 2004, 09:59 PM
campbellcj   Oh yeah...forgot to ask, exactly how hot are we ta...   Feb 26 2004, 10:11 PM
stecz   I'm opposed to cutting up the car for a front ...   Feb 26 2004, 10:57 PM
campbellcj   I'm pretty sure it's got the Mocal sandwic...   Feb 26 2004, 11:47 PM
- Lo-Fi Version Time is now: 16th July 2025 - 03:43 AM
