1975 Porsche 914 1.8, Need Help in Pasadena, California |
nigolusa |
Mar 23 2009, 11:30 AM
nigolusa Group: Retired Members Posts: 157 Joined: 10-November 08 From: los angeles Member No.: 9,737 Region Association: Southern California |
Is anybody willing to help me diagnose my starting problem? I live near the Rose Bowl. Car cannot be driven. Willing to compensate for efforts. Thank you!!!
zonedoubt |
Mar 31 2009, 12:11 PM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
Well the dual relay came. Got voltage everywhere. Pushed AFM door and fuel pump is active. Removed fuel line, pushed AFM door, fuel discharging. All hooked up correctly. Turn the key, nothing!!! Huge delay, then starter finally cranks, but engine doesn't fire. Any ideas anybody. Faulty ignition switch (easy & cheap to replace), poor wiring between switch and relay (trace & replace), poor starter connections (clean them up). |
nigolusa |
Mar 31 2009, 12:54 PM
Well the dual relay came. Got voltage everywhere. Pushed AFM door and fuel pump is active. Removed fuel line, pushed AFM door, fuel discharging. All hooked up correctly. Turn the key, nothing!!! Huge delay, then starter finally cranks, but engine doesn't fire. Any ideas anybody. Faulty ignition switch (easy & cheap to replace), poor wiring between switch and relay (trace & replace), poor starter connections (clean them up). Thanks will try |
benalishhero |
Mar 31 2009, 05:36 PM
Member Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States |
Are the injectors firing? Have you checked for spark? How about the grounds to the duel relay?
I've also experienced the spade connectors pushing out of the relay connectors as you plug it in. |
Lo-Fi Version | Time is now: 20th May 2024 - 12:20 PM |
