WTB Mahle Euro Spec Pistons and Cylinder set, Mahle 94mm Euro Spec |
patrick3000 |
Mar 23 2009, 12:09 PM
Member Group: Members Posts: 192 Joined: 19-July 06 From: Maryland Member No.: 6,468 |
The madness has already started, I am looking for a set of four:
Mahle 94mm Euro Spec (8.0:1 Compression) 914 2.0 (1973-76) Pistons and Cylinders. Please respond to this thread with pictures if you have a set. Regards |
type47 |
Mar 23 2009, 12:39 PM
Realize that these 2.0L pistons might not work on a 1.7L crankshaft. I think the best you can do is get 96mm pistons and get a 1911cc engine.
PS, Unless of course you are also looking for or have a 71mm crank and rods..... |
tradisrad |
Mar 23 2009, 01:02 PM
Rich at High performance House in Redwood City CA will likely have them. 650 364 6234. he will also be able to tell you if they will work for your application
patrick3000 |
Mar 23 2009, 01:12 PM
Realize that these 2.0L pistons might not work on a 1.7L crankshaft. I think the best you can do is get 96mm pistons and get a 1911cc engine. PS, Unless of course you are also looking for or have a 71mm crank and rods..... Jim, I'm also looking for a 2.0 bus engine for the crank and rods. Already have an extra set of 2.0 heads from the 912E rebuild. The last step will be carbs, a cam and a header. I expect it will take some time to acquire all of the parts. Let me know if you run across something interesting. |
patrick3000 |
Mar 23 2009, 01:19 PM
Rich at High performance House in Redwood City CA will likely have them. 650 364 6234. he will also be able to tell you if they will work for your application Thanks, I'll give him a call. Any other leads? (IMG:style_emoticons/default/driving.gif) |
hot_shoe914 |
Apr 3 2009, 10:05 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
Get me the Mahle part numbers. I have a connection here with the Mahle distribution center and can get great prices. I will see what I can do. I am about to buy some p/c sets so might get a better price the more I buy.
MrKona |
Apr 3 2009, 11:18 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
There is an Ebay auction for a new set here.
I've been watching this auction just for kicks. Nobody bid the first time around at $625. Relisted now and still no bids. This is a great deal if you can get them this cheap! (I have no affiliation with the seller). |
patrick3000 |
Apr 21 2009, 02:50 PM
Found a NOS set of 96mm NPR's. Thanks for the leads.
Lo-Fi Version | Time is now: 20th May 2024 - 05:21 AM |
