Engine deck lid seals Who needs one?, $26 or $22 See Thread |
Mikey914 |
Apr 3 2009, 02:01 PM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
This is a sample from the first die test run. It has an aluminum blip instead of the steel like OEM. The combination or heat from the engine with moisture causes the OEM to rust and crack. This one will not. It is 1/16" longer than the OEM to belp hide the deck lid gap if yours is not perfectly alligned.
I did notice that with the deck lid installed it was a pain to install, so I will make these available in a 2 part format where you can press the clip on, put the seal over the clip and glue the two together in palce. I can do the 2 part kit for $22. I personally think it's much easier to install this way. The flap is actually 1/16" longer than OEM to hide some of your deck lid allignment issues. These will be available to ship April 23rd. Attached image(s) |
craig downs |
Apr 3 2009, 02:36 PM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
Yes Yes Yes I need one bad sign me up
6freak |
Apr 3 2009, 02:57 PM
yes two please (IMG:style_emoticons/default/biggrin.gif) ..and send MR 242 the bill (IMG:style_emoticons/default/lol-2.gif)
ConeDodger |
Apr 3 2009, 03:10 PM
Apex killer! Group: Members Posts: 23,587 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
umm yep. 1 please...
A&PGirl |
Apr 3 2009, 03:50 PM
Senior Member Group: Members Posts: 1,019 Joined: 4-January 06 From: Oklahoma Member No.: 5,367 Region Association: None |
You know it.
I'll take 3 |
jmill |
Apr 3 2009, 03:58 PM
I'm in.
McMark |
Apr 3 2009, 07:37 PM
Two for me.
treemn |
Apr 3 2009, 08:32 PM
Member Group: Benefactors Posts: 50 Joined: 25-December 02 From: Klamath Falls,Oregon Member No.: 13 Region Association: None |
One please.
burton73 |
Apr 3 2009, 11:30 PM
burton73 Group: Members Posts: 3,524 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I an in for two sets when you are ready.
Thanks, Bob |
Todd Enlund |
Apr 4 2009, 01:12 AM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
I'll definitely be in for one when I find a job...
gothspeed |
Apr 4 2009, 01:40 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
I think I am gonna need one of these too (IMG:style_emoticons/default/smile.gif)!!!
FourBlades |
Apr 4 2009, 03:32 PM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
I can use a couple of those too... John |
carr914 |
Apr 4 2009, 05:50 PM
Racer from Birth Group: Members Posts: 118,648 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I'm in for 2 (I need a job too, but I'll buy when your ready)
T.C. |
slow914 |
Apr 4 2009, 06:30 PM
Member Group: Members Posts: 150 Joined: 5-February 08 From: Kirkland, WA Member No.: 8,671 Region Association: Pacific Northwest |
oh snap, yes sir 1 for me
Mikey914 |
May 3 2009, 10:47 PM
Well, here's some pictures of my install on one of my project cars. With the deck lid on the challange is to get it on so that it sits where you want it. This is had in the corners where there is extra material in the channel and you don't want to mess with trying to dig it out for fear of messing up your paint. This is where it's handy to be able to have a void to allow for the extra material in the gap. For this installation I placed the clip material on the lip then placed the rubber in position and glued it down with a shoe goo. It just takes a little. You could use 3M weather strip adheasive as it dosen't dry if you wish, or even rubber cement. It really dosen't take much as even without the glue the rubber sit in place well, the glue is primarily to keep it from moving.
PM me if you want one, let me know if you want it pre-glued or not. Attached image(s) |
lotus_65 |
May 4 2009, 05:26 AM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
okgoodsurefine.
one please. unglued. -thefleur |
VoPo914 |
May 4 2009, 06:34 AM
Member Group: Members Posts: 74 Joined: 11-January 07 From: Lincoln, Nebraska Member No.: 7,449 Region Association: Northstar Region |
I'll take one-unglued.
Blaine |
Lo-Fi Version | Time is now: 16th May 2024 - 06:06 PM |
