Recommended tune up procedure, How do you do yours? |
Engman |
Feb 26 2004, 09:59 PM
Zoisite Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 |
Well, it is time to get the teener out again - retaged it today! But before I make it the nearly every day driver I want to do a tune up. What is the consensus of what should be done first , second etc.
I had planned 1. timing 2. no need to do dwell as it is a Crane XR700 unit 3. plug gaps 4. valves 5. idle set M |
d7n7master |
Feb 26 2004, 10:16 PM
Gary# Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 |
Just my 2c but, I also have the Crane XR700 unit. My timing hasn't changed in four years. If it was my sometime driver I would; change the oil & filter, clean whatever sucks air, and spray a little "snoop" on all vacuum hoses to check for leaks. If you haven't replaced f.i. hoses-assuming that... do it NOW. Change the fuel filter. Find a twisty road. (IMG:style_emoticons/default/smile.gif)
garyh |
Feb 26 2004, 11:48 PM
Member Group: Members Posts: 170 Joined: 8-January 03 From: San Mateo, CA Member No.: 114 |
Valves 1st; you want the engine cold.
Take the plugs out while you do the valves; makes it easier. I replace plugs rather than re-gap them. If they're worn to the point where the gap has changed, it's time. (And I always use a torque wrench on the plugs.) Warm the engine up, then check the timing and idle speed. Snoop for vacuum leaks while it warms up. After the timing is checked (if the timing moves when you have a XR700 or Pertronix, think about worrying... ) drain the oil. Replace all filters. Then drive the darm thing! |
John |
Feb 27 2004, 02:09 AM
Here is what I like to do:
Start with a warm car and put it up on jack stands or in my case, my lift. Drain the oil. Allow engine to cool overnight. Pull all spark plugs. Remove valve covers. Set valve clearances. Install valve covers. Remove oil filter. Install new oil filter. Install oil drain plug. Fill with oil. Install new spark plugs. Install new air filter. Depending on when it was last changed, change fuel filter. Drive, drive, drive. If the car had been sitting a long time, you could flush the brake fluid as it does absorb water just sitting there.... |
Rusty |
Feb 27 2004, 09:34 AM
Wanted: Engine case GA003709 Group: Admin Posts: 7,941 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
Way back, John Larson recommended not pulling the plugs prior to a valve adjustment. Carbon build up could break free, and cause your valve adjustment to be "off".
Just a thought. If you're gonna replace plugs - then do them first, warm up the engine, drain the oil, then do valves. -Rusty (IMG:style_emoticons/default/smoke.gif) |
Freedom |
Feb 27 2004, 09:42 AM
Member Group: Members Posts: 79 Joined: 26-February 04 From: Colorado Member No.: 1,722 |
warm the engine up? shouldnt you adjust the the valves while the engine is cold?
or was i misunderstanding. i have this 1835 and i pulled the plugs on it and one of the valves got a piece of carbon fell on the seat or something, anyways the valve got stuck open slightly it wouldnt seat. as soon as i fierd it the valve loosend way up. my .02c |
Rusty |
Feb 27 2004, 10:35 AM
I should have said... "warm up the engine, drain the oil, let sit overnight, do valves."
Thanks for catching that! -Rusty (IMG:style_emoticons/default/smoke.gif) |
Freedom |
Feb 27 2004, 11:33 AM
or you could get it hot, and adjust them to zero clearance... for maximum valve lift... i do it on my Formula Vee, i still cant get it right!LOL
tat2dphreak |
Feb 27 2004, 11:40 AM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
QUOTE(Freedom @ Feb 27 2004, 11:33 AM) or you could get it hot, and adjust them to zero clearance... for maximum valve lift... i do it on my Formula Vee, i still cant get it right!LOL I would not want to stick my hand in the head to adjust the valves hot... much easier cold |
Lo-Fi Version | Time is now: 20th May 2024 - 01:32 PM |
