Quick question on point contact plates |
tod914 |
Apr 7 2009, 10:10 AM
Just cleaned the distributor. Does the contact plate bearing and the area where the 2 plates adjoin get bosch grease? motor oil? or leave dry?
Thanks, Tod |
dr914@autoatlanta.com |
Apr 7 2009, 10:21 AM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Cevan |
Apr 7 2009, 10:22 AM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
I'll chime in here b/c I just had this all part. My upper contact plate had three raised areas that ride on the lower plate. I cleaned everything and then lightly lube the raised areas on the upper plate and the contact area on the lower plate with a small amount of lube. I used distributor cam grease just because that's what I had out. I also cleaned and lubed the lower cam that the trigger points ride on.
tod914 |
Apr 7 2009, 10:26 AM
Ok thanks guys. Appreciate that. George the gaskets should be here this week. I'll ship soon as they arrive. They were kind of dragging their feet on the redo.
Apr 7 2009, 10:29 AM
we also had new dist points plates made in China because Bosch discontinued them. (by the way!!!) Thanks for the update on the gaskets Tod.
tod914 |
Apr 7 2009, 10:35 AM
Seen your ad on ebay for them George. Looks like they turned out real nice.
jt914-6 |
Apr 7 2009, 03:52 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
On top of the dist. shaft where the rotor goes, there sould be a felt piece. Add a couple drops of motor oil in there.
Lo-Fi Version | Time is now: 18th May 2024 - 07:40 PM |
