mocal sandwhich plate ? |
ynotdd |
Feb 27 2004, 09:03 AM
Member Group: Members Posts: 156 Joined: 13-January 03 From: plainview, NY Member No.: 140 |
I am going to put a front oil cooler in my 73 2.0/4 that i use for autocross and DE . Has anyone used the Mocal oil sandwhich plate with the thermostat in it? and what size lines should i run ?
I have an RX7 cooler or should i get something else? (IMG:style_emoticons/default/chair.gif) |
Evill Ed |
Feb 27 2004, 11:41 AM
Member Group: Members Posts: 238 Joined: 28-February 03 Member No.: 371 Region Association: None |
I run one and use -10 lines with it.
Ed |
porsche735 |
Feb 27 2004, 11:43 AM
Member Group: Members Posts: 189 Joined: 10-January 03 From: Los Altos, CA Member No.: 127 |
I run one and ran -12 lines. Make sure you use the aluminum ends on your lines so the expansion is the same rate. It is tough to get these things sealed up right.
Chris |
cha914 |
Feb 27 2004, 11:57 AM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
Ditto...I used -10 aeroquip rubber lines w/ alum fittings...pics of my install here:
http://www.914world.com/bbs2/index.php?act...&f=2&t=7103&hl= I basically copied Ed's setup from a while back... Good luck, Tony |
Lo-Fi Version | Time is now: 10th May 2024 - 01:42 AM |
