I am going to put a front oil cooler in my 73 2.0/4 that i use for autocross and DE . Has anyone used the Mocal oil sandwhich plate with the thermostat in it? and what size lines should i run ? I have an RX7 cooler or should i get something else?
Evill Ed
Feb 27 2004, 11:41 AM
I run one and use -10 lines with it.
Ed
porsche735
Feb 27 2004, 11:43 AM
I run one and ran -12 lines. Make sure you use the aluminum ends on your lines so the expansion is the same rate. It is tough to get these things sealed up right.
Chris
cha914
Feb 27 2004, 11:57 AM
Ditto...I used -10 aeroquip rubber lines w/ alum fittings...pics of my install here:
