FS More of Bruce's plated parts, if you do not see it , ask I may have it |
bdstone914 |
Apr 7 2009, 10:40 PM
I just got back a large batch of plated parts. Here are some that I have had a chance to sort and photograph. Shipping is $5 for as many part as will fit in a flat rate USPS envelope or $10 for as many parts as will fit in a flat rate box. I often have more sets of parts than are shown in the pictures.
Gas cap $20 (IMG:http://img113.imageshack.us/img113/5003/dscf0954.th.jpg) Pair of valve covers $25 (IMG:http://img379.imageshack.us/img379/1832/dscf0952.th.jpg) Trans Pulley bracket $15 (IMG:http://img113.imageshack.us/img113/6545/dscf0950.th.jpg) Front hood springs $20 (IMG:http://img159.imageshack.us/img159/9682/dscf0948.th.jpg) Gas tank straps $20 (IMG:http://img144.imageshack.us/img144/5897/dscf0947.th.jpg) Strut hold down plates, bolts, new washers $20 /2 sets (IMG:http://img144.imageshack.us/img144/7688/dscf0945.th.jpg) Front upper hood latches $20 Front lower hood latches $20 (IMG:http://img509.imageshack.us/img509/9986/dscf0942.th.jpg) Rear trunk upper latch with metal slider $25 Ball joint hardware $25 (IMG:http://img26.imageshack.us/img26/1849/dscf0965v.th.jpg) 2 Stub axle Castle nuts with washers $25 (IMG:http://img513.imageshack.us/img513/5871/dscf0964.th.jpg) Torsion bar adjusters with screws $20 (IMG:http://img227.imageshack.us/img227/587/dscf0962.th.jpg) Brake reservoir straps $15 each (IMG:http://img26.imageshack.us/img26/8499/dscf0959d.th.jpg) Coil brackets for fan shroud mount $10 (IMG:http://img520.imageshack.us/img520/6866/dscf0957.th.jpg) Coil brackets for cylinder tin mount $7 (IMG:http://img13.imageshack.us/img13/407/dscf0958f.th.jpg) Engine lid latches $10 (IMG:http://img14.imageshack.us/img14/5260/dscf0956h.th.jpg) CV joint bolts, clips and new Schnorr washers $20 per set for both axles (IMG:http://img14.imageshack.us/img14/7598/dscf0967.th.jpg) |
jeeperjohn56 |
Apr 7 2009, 11:30 PM
Member Group: Members Posts: 479 Joined: 9-July 06 From: Antioch,Ca. Member No.: 6,407 Region Association: None |
Hey Bruce, Did you get any trans mounts done?still waiting for mine and brake clips.John (IMG:style_emoticons/default/confused24.gif)
kconway |
Apr 9 2009, 08:59 AM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
Bruce,
I need a set of those torsion bar adjusters to go along with the A-arms I got from you. I also need one LARGE aircleaner latching clip. Kevin |
charliew |
Apr 9 2009, 09:59 AM
Nice parts and good prices. Are these cadmium or copy cad plated?
bdstone914 |
Apr 9 2009, 06:18 PM
charliew |
Apr 9 2009, 08:16 PM
Thats ok I think that is really a better coating. Caswell calls it a copy cad. Will you have these parts later on I probably will want some at a later date.
Lo-Fi Version | Time is now: 20th May 2024 - 06:05 AM |
