I just got back a large batch of plated parts. Here are some that I have had a chance to sort and photograph. Shipping is $5 for as many part as will fit in a flat rate USPS envelope or $10 for as many parts as will fit in a flat rate box. I often have more sets of parts than are shown in the pictures.
Gas cap $20
Pair of valve covers $25
Trans Pulley bracket $15
Front hood springs $20
Gas tank straps $20
Strut hold down plates, bolts, new washers $20 /2 sets
Front upper hood latches $20
Front lower hood latches $20
Rear trunk upper latch with metal slider $25
Ball joint hardware $25
2 Stub axle Castle nuts with washers $25
Torsion bar adjusters with screws $20
Brake reservoir straps $15 each
Coil brackets for fan shroud mount $10
Coil brackets for cylinder tin mount $7
Engine lid latches $10
CV joint bolts, clips and new Schnorr washers $20 per set for both axles
