Replacing Angle Drive Seal, What am I missing? |
MBowman325 |
Apr 9 2009, 06:56 PM
Member Group: Members Posts: 465 Joined: 14-July 05 From: Oklahoma City, OK Member No.: 4,413 Region Association: Southwest Region |
I think I've figured this out, and if so, then I'm missing what might be a critical piece. Tell me what you think.
Gear drive | Seal | Al housing (with O ring) | Angle drive Is there supposed to be a washer between the drive gear and the seal?? |
jonferns |
Apr 9 2009, 06:59 PM
Hmm...good question. Just had mine apart a few days ago to replace the o-ring, which is the angle drive seal. I should've taken a picture while it was apart, sorry I can't be of any help.
McMark |
Apr 9 2009, 07:35 PM
63 is the seal
62 is listed a 'sealing washer' I don't have one apart here to look at. Attached image(s) |
MBowman325 |
Apr 9 2009, 07:38 PM
63 is the seal 62 is listed a 'sealing washer' I don't have one apart here to look at. OK. That's what I was hoping for... Now. How the hell do you get that out??? I'm actually glad this happened. I've been in the garage since I got home. I didn't know that there were some big fires going on around me. Just stepped onto the porch and the eastern sky is lit up. Tinker is north of my, so not sure how bad it is there. (Heard over 100 homes have gone down, and they've quitting on houses trying to contain grass fires... Guess I need to load up... Damn wind. |
MBowman325 |
Apr 9 2009, 07:52 PM
Disregard. I managed to pry it out without any apparent damage. Did spend almost five minutes looking for it afterwards though.
kconway |
Apr 9 2009, 08:52 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
Disregard. I managed to pry it out without any apparent damage. Did spend almost five minutes looking for it afterwards though. 62 is an aluminum crush washer...need it. Look here: http://www.914world.com/bbs2/index.php?sho...;hl=angle+drive |
MBowman325 |
Apr 9 2009, 09:51 PM
Disregard. I managed to pry it out without any apparent damage. Did spend almost five minutes looking for it afterwards though. 62 is an aluminum crush washer...need it. Look here: http://www.914world.com/bbs2/index.php?sho...;hl=angle+drive That was the thread I was looking for earlier. Found the other two that I remembered about slow leaks of the 901. I buttoned it up earlier after changing the reverse pin and filled it back up with fluid. Drove it down to the gas station and the shifts feel different now... Must be how I have the seat (IMG:style_emoticons/default/biggrin.gif) . (Changed rear springs (shocks still dead) and fuel filter / front lines.) Just in time for the weather to turn chilly again.... |
Apr 9 2009, 10:00 PM
Tell me what you think. Gear drive | Seal | Al housing (with O ring) | Angle drive I think you got the seal on the wrong end. (IMG:style_emoticons/default/shades.gif) Andy |
Cap'n Krusty |
Apr 9 2009, 10:09 PM
Disregard. I managed to pry it out without any apparent damage. Did spend almost five minutes looking for it afterwards though. 62 is an aluminum crush washer...need it. Look here: http://www.914world.com/bbs2/index.php?sho...;hl=angle+drive I'll guarantee that, while it MAY be aluminum, it's NOT a "crush" washer. The Cap'n |
kconway |
Apr 9 2009, 10:15 PM
Disregard. I managed to pry it out without any apparent damage. Did spend almost five minutes looking for it afterwards though. 62 is an aluminum crush washer...need it. Look here: http://www.914world.com/bbs2/index.php?sho...;hl=angle+drive I'll guarantee that, while it MAY be aluminum, it's NOT a "crush" washer. The Cap'n Whatever...it's a washer that gets deformed once installed...call it what you want. |
Apr 9 2009, 10:35 PM
Whatever...it's a washer that gets deformed once installed... I don't think so ... When i replaced mine, it was pretty thick and solid. You would have a hard time getting that thing deformed short of hitting it with a hammer. Crush washers usually are hollow or folded over to allow the metal to deform. (IMG:style_emoticons/default/bye1.gif) Andy |
kconway |
Apr 9 2009, 10:52 PM
Whatever...it's a washer that gets deformed once installed... I don't think so ... When i replaced mine, it was pretty thick and solid. You would have a hard time getting that thing deformed short of hitting it with a hammer. Crush washers usually are hollow or folded over to allow the metal to deform. (IMG:style_emoticons/default/bye1.gif) Andy Yeah, maybe I'm calling an apple an orange here and maybe the one I replaced was buggered up by the PO. Here is a photo of the seal I removed, it where it was deformed. (IMG:style_emoticons/default/biggrin.gif) BEFORE AFTER |
Lo-Fi Version | Time is now: 16th May 2024 - 03:20 PM |
