Bought Tarret drop links. Need pics of your setup, Not sure what I need for spacers for U-tabs |
JRust |
Apr 10 2009, 08:37 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I could use some pics of drop links setups. The Tarret adjustable drop links I bought don't come with hardware. Seems like I'll need some for the Utabs on the A-arm. Thanks in advance
CliffBraun |
Apr 10 2009, 09:25 PM
Member Group: Members Posts: 252 Joined: 26-April 06 From: San Luis Obispo,ca Member No.: 5,933 Region Association: None |
I can't get a good pic right now, if nobody's gotten one for ya by tomorrow morning I'll take one.
Apr 10 2009, 09:49 PM
I could use some pics of drop links setups. The Tarret adjustable drop links I bought don't come with hardware. Seems like I'll need some for the Utabs on the A-arm. Thanks in advance It's just a bolt a locknut. The red "spacers" you have slide inside the hole on each end of the droplinks and act as "bearings". All you need is a bolt that fits tight through those red spacers. I use bolts with an allen head and no thread in the center. Below is a pictures of the droplinks i broke but you can see the bolts for reference. (IMG:style_emoticons/default/bye1.gif) Andy |
Apr 10 2009, 09:51 PM
And another pic with the top bolt ...
PRS914-6 |
Apr 11 2009, 09:01 AM
Here is how the kit comes, where you need to mount the tab and installed
JRust |
Apr 11 2009, 10:22 AM
Thanks for the pics (IMG:style_emoticons/default/biggrin.gif) . Look slike I have what I need then. Just seemed like the U-tabs would be to wide without some spacers between the drop links. Guess they will be fine. I have the bolts from my original. I was just mistaken thinking I needed more hardware. As always you guys rock (IMG:style_emoticons/default/aktion035.gif)
PRS914-6 |
Apr 11 2009, 10:30 AM
You need the spacers. Look at Andy's picture and you can see them and in the pile of nuts and bolts in my pictures. Without them the joints are restricted in movement
JRust |
Apr 11 2009, 10:34 AM
PRS914-6 |
Apr 11 2009, 11:03 AM
Probably direct from Tarrett, if you don't have a lathe. The step fits inside the heim joint. Whatever method you use, make sure the bolt is a snug fit through the heim and bracket or the bar will clunk a won't work well.
PeeGreen 914 |
Apr 11 2009, 11:15 AM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Jamie, in your first picture you have four like things right next to the drop links. Those are the spacers.
JRust |
Apr 11 2009, 12:04 PM
(IMG:style_emoticons/default/headbang.gif) Oh (IMG:style_emoticons/default/huh.gif) LOL I'm a little off this morning. Good catch there Jon
Jamie, in your first picture you have four like things right next to the drop links. Those are the spacers. |
PRS914-6 |
Apr 11 2009, 12:07 PM
Yes, that was a good catch. I assumed that was a generic picture since he said he didn't have any hardware. That's what I get for assuming..... (IMG:style_emoticons/default/wacko.gif)
Lo-Fi Version | Time is now: 16th May 2024 - 05:18 PM |
