Solid or Hydraulic lifter, Help Identify |
t collins |
Apr 11 2009, 05:59 PM
Advanced Member Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
I'm about 99% sure that this is a Hydraulic lifter but I would like someone else to confirm that it is or isn't.
Thanks, |
messix |
Apr 11 2009, 06:08 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
does the cup push down when you push something down on it?
t collins |
Apr 11 2009, 06:18 PM
messix |
Apr 11 2009, 06:23 PM
it would only be collapsed if it were hydraulic. and you would see were the plunger hand recessed to. even the solid lifetrs are acually made in several pieces to allow for oil to get out the rockers. there is a valve inside and the ciclip holds the guts together. if it was a hydaulic lifter you could with force push the cup down some and it would return from spring pressure inside.
'73-914kid |
Apr 11 2009, 06:28 PM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
definetly a solid lifter. If it were hydraulic, you would see the retaining clips. Compare that lifter to these:
(IMG:http://www.panteraplace.com/351C/Mikes%20lifters%202.jpg) |
messix |
Apr 11 2009, 06:34 PM
this explains the hydraulic lifter http://images.google.com/imgres?imgurl=htt...sa%3DN%26um%3D1
McMark |
Yup. Solid.
t collins |
Apr 11 2009, 06:39 PM
Many thanks guys! (IMG:style_emoticons/default/beerchug.gif)
Jake Raby |
Apr 11 2009, 07:18 PM
Solid.. Looks like a last generation Johnson lifter...
Lo-Fi Version | Time is now: 16th May 2024 - 10:38 AM |
