does the cup push down when you push something down on it?
t collins
Apr 11 2009, 06:18 PM
QUOTE(messix @ Apr 11 2009, 04:08 PM)
I can't push it but would you be able to is it were collapsed? looks like the inside cup is made separate form the body of the lifter.
messix
Apr 11 2009, 06:23 PM
it would only be collapsed if it were hydraulic. and you would see were the plunger hand recessed to. even the solid lifetrs are acually made in several pieces to allow for oil to get out the rockers. there is a valve inside and the ciclip holds the guts together. if it was a hydaulic lifter you could with force push the cup down some and it would return from spring pressure inside.
'73-914kid
Apr 11 2009, 06:28 PM
definetly a solid lifter. If it were hydraulic, you would see the retaining clips. Compare that lifter to these:
