pictures of my parts!!, 2056 pieces... |
DrifterJay |
Feb 27 2004, 06:35 PM
I break stuff... Group: Members Posts: 1,034 Joined: 25-May 03 From: Oceanside, California Member No.: 737 Region Association: None |
heres a few pics I took last week of some the hardware going in my 2056...motor should have been done today...but the 96pc are running late...
DrifterJay |
Feb 27 2004, 06:36 PM
counterweighted crank
Aaron Cox |
way cool man. you get the exhaust sorted yeT?
DrifterJay |
Feb 27 2004, 06:37 PM
straight cuts
DrifterJay |
Feb 27 2004, 06:38 PM
webcam is standard 86grind
DrifterJay |
ah memories...
DrifterJay |
Feb 27 2004, 06:41 PM
yeah I am temporarily going to run a stock 1.7 muffler till I get more money then my builder will use the stock exhangers but will chop a bus header on the end with a collector and a supertrapp spark arrestor... only 150 bucks...will make good vacuum and wont be too loud
URY914 |
Feb 27 2004, 07:34 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,563 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I like the straight cut gears. People don't talk much about them. Why did you decide to use them?
Paul |
RD Evans |
Feb 27 2004, 07:38 PM
Member Group: Members Posts: 112 Joined: 20-July 03 From: Temple, TX Member No.: 923 |
Jay...would you share your sources for your parts? I'm hoping to build a 2056 out of my 1.8 soon. I've been saving Raby's video for over a year and I'm finally close to being ready to start the project!
Rgreen914 |
Feb 27 2004, 07:52 PM
Member Group: Members Posts: 285 Joined: 20-October 03 From: West Covina, Ca. Member No.: 1,266 |
QUOTE(URY914 @ Feb 27 2004, 05:34 PM) I like the straight cut gears. People don't talk much about them. Paul Paul Are you running straight cut gears on a street car? Are they as noisy as people say? I know of a couple of Chevies that run them and you can hear them coming a block before they arrive; makes you think they're running a blower. Definitely not "stealth mode" for a streeter. |
Mark Henry |
Feb 27 2004, 08:01 PM
QUOTE(Rgreen914 @ Feb 27 2004, 05:52 PM) QUOTE(URY914 @ Feb 27 2004, 05:34 PM) I like the straight cut gears. People don't talk much about them. Paul Paul Are you running straight cut gears on a street car? Are they as noisy as people say? I know of a couple of Chevies that run them and you can hear them coming a block before they arrive; makes you think they're running a blower. Definitely not "stealth mode" for a streeter. Yep noisy...at least the T1 ones are. You either like em or totally hate em. |
Jake Raby |
Feb 27 2004, 08:09 PM
WATCH THOSE GEARS!
They are from MSHP's last run..... I have seen 4 camshafts snap in half right in front of the cam thrust- gears are elliptical and have run out (some of them more than others) They also make it more difficult to run a TI oil pump... |
Rgreen914 |
Feb 27 2004, 08:14 PM
QUOTE(Jake Raby @ Feb 27 2004, 06:09 PM) I have seen 4 camshafts snap in half right in front of the cam thrust... Mark Would this make them even more noisy? |
Mark Henry |
Feb 27 2004, 08:16 PM
Hmmm...sounds like a new plan might be in order.
Who was MSHP? |
Mark Henry |
Feb 27 2004, 08:17 PM
QUOTE(Rgreen914 @ Feb 27 2004, 06:14 PM) QUOTE(Jake Raby @ Feb 27 2004, 06:09 PM) I have seen 4 camshafts snap in half right in front of the cam thrust... Mark Would this make them even more noisy? Only for a second or two! (IMG:style_emoticons/default/unsure.gif) |
Jake Raby |
Feb 27 2004, 08:25 PM
Mark Stephens High Performance.
Mark Henry |
Feb 27 2004, 08:30 PM
QUOTE(Jake Raby @ Feb 27 2004, 06:25 PM) Mark Stephens High Performance. (IMG:style_emoticons/default/icon8.gif) (IMG:style_emoticons/default/barf.gif) RUN FOREST RUN!!!!!! |
rhodyguy |
Feb 27 2004, 08:32 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,079 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
rich denhauer should tell his mshp tale. you better be listening to these guys jay.
kevin |
Rgreen914 |
Feb 27 2004, 08:39 PM
Maybe his "problems" were due to the altitude of his location; Tehachapi is over 4,000 feet up! Strange things happen in that town...like snow on the 4th of July!
Lo-Fi Version | Time is now: 14th May 2024 - 11:43 AM |
