5 lug rotors, i have a remedy for whats ailing me......with lots of pics |
firstknight13 |
Apr 13 2009, 09:35 PM
Senior Member Group: Members Posts: 652 Joined: 25-March 05 From: manchester,ct. Member No.: 3,817 |
(IMG:style_emoticons/default/biggrin.gif) ok i got my rear hubs changed and put on my 5 lug rotors ...look nice....put caliper on and oops it dont fit....wrong rotor...so now would one of you please give to me the right pn for rear rotor......4-5 redrilled rear hubs....every thing nos the pn i have is 901-352-041-14 it is too deep...the caliper i am using has the spacer for vented rotors.....thanks in advance......ray
TC 914-8 |
Apr 13 2009, 11:38 PM
Senior Member Group: Members Posts: 809 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest |
If you have the rear caliper with the spacer installed you MAY need the 74-78 911 rear rotors with 4mm taken off the circumfrence( out side edge)
Eric Shea @PMB performance is the man to talk to. He has a couple threads in the classics, on how to rebuild rear brakes. Either way he can steer you in the right direction. I have a set of solid 5-lug rear rotors if thats what you need. I'll let them go for $25 ea plus shipping. |
Wilhelm |
Apr 14 2009, 03:05 AM
Member Group: Members Posts: 408 Joined: 7-September 07 From: Hooterville, OR Member No.: 8,088 Region Association: None |
When you say doesn't fit: do you mean disc is too fat-skinny or the diameter too big-small?
If diameter too big, borrow a lathe or find a machinist and turn down the diameter a squosh. |
davep |
Apr 14 2009, 02:57 PM
What calipers are you using? 914/4 widened?
What rotors are you using? The 944 replacements can be too thick at 20.5mm and too big in diameter. You need to machine down to the stock diameter. If you did not use the bracket for the dust shield or the spacer on the hub, then the alignment of the caliper to rotor could be wrong. |
firstknight13 |
Apr 16 2009, 05:43 AM
(IMG:style_emoticons/default/biggrin.gif) all set thanks to CFR racing......nice to have chris and ed close by for inspiration (IMG:style_emoticons/default/driving.gif)
davep |
Apr 16 2009, 07:00 AM
SO! Fess up, what was the solution?
johnnie5 |
Apr 16 2009, 12:17 PM
914 lover Group: Members Posts: 375 Joined: 14-October 08 From: San Diego, CA Member No.: 9,644 Region Association: Southern California |
Yes.... splain (IMG:style_emoticons/default/huh.gif)
firstknight13 |
Apr 16 2009, 10:57 PM
(IMG:style_emoticons/default/biggrin.gif) old old secert......turned out to be simple...911 vented rotors....had 1/8" taken off the OD (outside diameter) that mean 1/4" total.....needed 3 12mm washers to center the 911 caliper so now i need longer screws to hold the caliper in place 3 washers longer the washers went in between the caliper and the mount......now all works except no e brake and the break shield wont fit so i will run without till i come up with a solution on that.....either way i will be at hershey....ray
firstknight13 |
Apr 16 2009, 11:33 PM
firstknight13 |
Apr 16 2009, 11:35 PM
(IMG:style_emoticons/default/biggrin.gif) notice the 3 washers......rotors are a perfect fit (IMG:style_emoticons/default/smoke.gif)
firstknight13 |
Apr 16 2009, 11:36 PM
(IMG:style_emoticons/default/biggrin.gif) with spacer
firstknight13 |
Apr 16 2009, 11:38 PM
(IMG:style_emoticons/default/biggrin.gif) with wheel
firstknight13 |
Apr 16 2009, 11:39 PM
(IMG:style_emoticons/default/biggrin.gif) yes i did use a pipe wrench.... (IMG:style_emoticons/default/mad.gif)
firstknight13 |
Apr 16 2009, 11:42 PM
(IMG:style_emoticons/default/biggrin.gif) inside view....have to relocate brake line now..... (IMG:style_emoticons/default/biggrin.gif) its all good....ray
davep |
Apr 17 2009, 06:11 AM
All the spacing issues are well documented in old threads.
charliew |
Apr 17 2009, 01:36 PM
Emergency brake as in using the 86 944 angle adjusters and shoes and the early 911 steel arm backing plates with a welded-on support inbetween the shoes. A short extension link to the 914 cable and changing the angle of the bracket will do the trick. If you want to go bigger bucks the boxter parts seem to be the same thing but maybe slightly narrower shoes. If you don't like the 914 handle you could also go to the 911 or 944 handle and cable.
Are those 7 or 8's? they get about as close to the arm as you could want. |
firstknight13 |
Apr 19 2009, 01:50 AM
(IMG:style_emoticons/default/biggrin.gif) they are 7 front 9 rear 3" fender flare via CFR...i have boxter big brakes and 944 turbo brake options i just want to make the MID ENGINE INVASION so this works for now...will check into your suggestation....thanks, ray (IMG:style_emoticons/default/driving.gif)
firstknight13 |
Apr 19 2009, 10:10 PM
(IMG:style_emoticons/default/biggrin.gif) all done brakes bleed......yeah !!! i like how the lines came out....ray
firstknight13 |
Apr 19 2009, 10:12 PM
(IMG:style_emoticons/default/biggrin.gif) driving tomorrow.......windshield install and front end alignment and i'm so good to go.........ray (IMG:style_emoticons/default/driving.gif)
sixnotfour |
Apr 20 2009, 02:56 AM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Is the bleeder nipple Up ?
Lo-Fi Version | Time is now: 19th May 2024 - 06:41 AM |
