Stripped CV bolts, How do ya get em out? |
markb |
Apr 14 2009, 03:04 PM
As the title asks.....
DAPO used some triple square, and some allen head. (IMG:style_emoticons/default/headbang.gif) |
SLITS |
Apr 14 2009, 03:11 PM
Vice grips ................ small ones
jcd914 |
Apr 14 2009, 03:20 PM
Which are stripped, allen or triple square?
I have had good success driving the triple square tool into the stripped allen bolts and then using a ratchet to remove them. It is a bit hard on the tool but Snap-on keeps giving me new ones. Triple square hardware is capable of handling more torque than allen hardware but too many people don't clean out either before trying to tighten or loosen, leading to stripped bolts. Vise grips are always a good option if there is enough room to get a hold of the bolt head. Good Luck Jim |
okieflyr |
Apr 14 2009, 03:21 PM
9fauxteen Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States |
As the title asks..... DAPO used some triple square, and some allen head. (IMG:style_emoticons/default/headbang.gif) I've had success welding bolts onto the heads and then backing them out. (IMG:style_emoticons/default/welder.gif) YMMV.... |
markb |
Apr 14 2009, 03:32 PM
A triple square on each side stripped. I cleaned & pounded the tool in, to no avail.
Apr 14 2009, 04:40 PM
Read what the slits said...
VICE GRIPS Rich |
markb |
Apr 14 2009, 04:43 PM
Read what the slits said... VICE GRIPS Rich No matter how tight I get the small vice grips (and they are new, with nice sharp teeth), it slips. (IMG:style_emoticons/default/mad.gif) |
Apr 14 2009, 04:45 PM
Use bigger ones.
I have broken vice grips by trying to get them on the hardened bolts...broken the front piece.. Also, use a dremel to flatten out two sides, then use vice grips. They will come loose. Use a hammer to loosen the threads a bit. Rich |
Cap'n Krusty |
Apr 14 2009, 05:05 PM
Curved jaw channel locks. I use the 10" ones if they'll fit, the battery clamp ones if they won't. Call me to arrange pickup ................ The Cap'n
markb |
Apr 14 2009, 05:31 PM
sww914 is stopping by tomorrow to hit them with the air chisel. (IMG:style_emoticons/default/smile.gif)
yeahmag |
Apr 14 2009, 05:53 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
If you have a dremel you can carefully cut the heads off with a fiberglass reinforced cutting wheel... Once the CV is off the threaded shank will come right out. Careful not to scar the retaining plate, but if you do they are plentiful.
-Aaron |
dbgriffith75 |
Apr 14 2009, 06:24 PM
TheGrif Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest |
What worked for me was to just remove the axle w/ the stub attached. Pull the bolts once it's out, and replace the stub axle in the car to keep wheel bearings in place.
charliew |
Apr 14 2009, 07:31 PM
Take a small flat chisel and put it flush dead center on the side horizontal or parallel to the axle and make a good groove then angle it ccw and knock it loose.
PeeGreen 914 |
Apr 14 2009, 07:40 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
I have to agree with SLITS and Cap'n on this one. Big channel locks or big vice grips always have worked for me many times. One of my parts cars had every single bolt stripped. The air chisel can just peal the bolt or slip past. I just don't like using them.
benalishhero |
Apr 14 2009, 07:45 PM
Member Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States |
Blue point makes a great easy-out (fitting over the OD)that will get them out np. I also use a hammer/chisel on them. If push comes to shove, use a slam hammer with the chisel attachment. Fun tool.
76-914 |
Apr 15 2009, 10:19 PM
Use a 4" Ridgid Pipe Wrench. The teeth are ground at an angle to bite into round head and the jaws form an angle of sorts so the grip tightens with torque. I've done this on my Ghia and 914 (PO leftovers).
Joe Bob |
Apr 16 2009, 10:09 AM
Channel locks or big Vise Grips....BTDT....
Get them off yet? |
markb |
Apr 16 2009, 11:18 AM
I haven't had much time to fuch with it. Hopefully today.
And the Snap-On truck just pulled up...... (IMG:style_emoticons/default/smile.gif) |
Cap'n Krusty |
Apr 16 2009, 12:01 PM
THIS is what you need!
http://www.channellock.com/acb/stores/1/ca...p;Category_ID=6 They work. There's not a lot of room in there to get both a grip and any kind of swing, but if you're patient, they do the job. I think I use the middle one, but I also have the one on the right. The Cap'n |
VaccaRabite |
Apr 16 2009, 12:14 PM
En Garde! Group: Admin Posts: 13,443 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I had one that I pounded a semi-ruined start point wrench into and then welded in place. Came out easy.
I have also used vice grips, but if you have a wrecked star point bit, welding it in may be faster. Zach |
Lo-Fi Version | Time is now: 16th May 2024 - 02:34 AM |
