/6 oil tank & filter |
ahdoman |
Apr 15 2009, 01:32 PM
It's phonetic...Ah-D-O-Man (Audioman) Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
Can somebody please post a pic of the right way to orient the oil filter mounting flange to the tank? The bolts will go in all three different rotations but I need to make sure I'm mounting the flange with the correct orientation to the tank lines.
ClayPerrine |
Apr 15 2009, 04:13 PM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
If you look carefully at the oil filter adapter, and the tank, you will see that there is a hole in the tank that matches up with a hole in the oil filter adapter. If you do not get the two aligned, you will not get any oil returned to the tank when the engine is running.
And that will ruin your whole day....... |
jt914-6 |
Apr 15 2009, 04:27 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Hope this helps.....
9146BRUCE |
Apr 15 2009, 05:52 PM
Member Group: Members Posts: 57 Joined: 16-April 07 From: Northridge Calif. Member No.: 7,670 Region Association: Southern California |
Hope this helps.
Bruce |
Lo-Fi Version | Time is now: 20th May 2024 - 06:29 PM |
