ahdoman
Apr 15 2009, 01:32 PM
Can somebody please post a pic of the right way to orient the oil filter mounting flange to the tank? The bolts will go in all three different rotations but I need to make sure I'm mounting the flange with the correct orientation to the tank lines.
ClayPerrine
Apr 15 2009, 04:13 PM
If you look carefully at the oil filter adapter, and the tank, you will see that there is a hole in the tank that matches up with a hole in the oil filter adapter. If you do not get the two aligned, you will not get any oil returned to the tank when the engine is running.
And that will ruin your whole day.......
