carb problem |
carb problem |
fitzm1 |
Apr 15 2009, 03:20 PM
Member Group: Members Posts: 74 Joined: 21-April 08 From: Ballston lake,ny Member No.: 8,947 Region Association: None |
Can't figure this one out. I went for a first time summer cruise. The car ran great but the idle was high. As I was adjusting the idle the car stalled, now it won't start. When I try to start it a puff of vapor comes out of No 3 carb.
Setup 40 IDF with MSD ignition. I am getting a spark. Mike |
dbgriffith75 |
Apr 15 2009, 06:40 PM
TheGrif Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest |
What were you adjusting the idle on? Carbs? Try the dizzy- if I'm not mistaken you can loosen a bolt right next to it and rotate the dizzy one way or another- I think clockwise advances timing and counter clock wise retards it. When you advance it should raise the idle, when you retard it should drop the idle down.
...at least, I think that's right... (IMG:style_emoticons/default/dry.gif) |
Cap'n Krusty |
Apr 15 2009, 06:49 PM
What were you adjusting the idle on? Carbs? Try the dizzy- if I'm not mistaken you can loosen a bolt right next to it and rotate the dizzy one way or another- I think clockwise advances timing and counter clock wise retards it. When you advance it should raise the idle, when you retard it should drop the idle down. ...at least, I think that's right... (IMG:style_emoticons/default/dry.gif) Excuse me? This is a joke, right? Besides, you have the direction wrong. You NEVER move the timing unless it's wrong. And you don't do it to adjust the idle speed, either. The Cap'n |
dbgriffith75 |
Apr 15 2009, 06:54 PM
jt914-6 |
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
To start with, clean and blow out the idle jets. Check float levels and pump quantity. Quantity should be between .6 & .8 cc. per stroke.
type2man |
Apr 15 2009, 07:43 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
Perhaps when you stuck you hand down in there you knocked a wire loose. Try putting back the idle back the same number of turns...
Lo-Fi Version | Time is now: 16th May 2024 - 04:22 PM |
