easy question about engine shields. |
JOE M |
Apr 16 2009, 04:11 PM
Member Group: Members Posts: 293 Joined: 27-August 07 From: N.H Member No.: 8,042 Region Association: None |
I had a couple of broken bolts on my intake manifolds and removed the engine shields to gain easier access. Do these shields act as a passive cooling system for the engine or can I run the car with them off. These are the shields that go over the cylinders and along the sides and back.
Apr 16 2009, 04:13 PM
You NEED all the engine tin (shields) in place and hooked up right.
This is what directs the air from the fan to the right place and keeps your car cool.. Without them your motor will overheat very quickly and die. Hows that for an answer... Rich |
Millerwelds |
Pleepleus Group: Members Posts: 715 Joined: 24-June 08 From: Grass Valley, CA Member No.: 9,206 Region Association: Northern California |
I had a couple of broken bolts on my intake manifolds and removed the engine shields to gain easier access. Do these shields act as a passive cooling system for the engine or can I run the car with them off. These are the shields that go over the cylinders and along the sides and back. Definitley needed for cooling. They control the air flow. |
JOE M |
Apr 16 2009, 04:15 PM
I had a couple of broken bolts on my intake manifolds and removed the engine shields to gain easier access. Do these shields act as a passive cooling system for the engine or can I run the car with them off. These are the shields that go over the cylinders and along the sides and back. Definitley needed for cooling. They control the air flow. Damn Rich you are fast!!!!!Thanks |
Lo-Fi Version | Time is now: 16th May 2024 - 03:08 AM |
