| kpfoten |
Apr 19 2009, 06:59 PM
Member ![]() ![]() Group: Members Posts: 220 Joined: 15-April 08 From: Escanaba, MI Member No.: 8,927 Region Association: None |
My sensor seems different (No wire coming off sensor) than what is available. My engine tin has a small hole for it, and I'm wondering if I have to take the tin off? Do I need the bracket attached? Engine is a 1.7L. Thanks!
| 3d914 |
Apr 19 2009, 07:15 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
Kris,
The reason its different is because that's the Air Temp Sensor #1 (of two - the other is smaller and in the plenum -air box) The head temp sensor is about the diameter of your finger, with threads on one end and the lead wire you were expecting on the other end. Take a look at Pelican Parts Catalog for more details. It will also show location. Good luck. |
| kpfoten |
Apr 20 2009, 10:14 AM
Thanks!
Where does the #1 Air Temp Sensor mount? Kris, The reason its different is because that's the Air Temp Sensor #1 (of two - the other is smaller and in the plenum -air box) The head temp sensor is about the diameter of your finger, with threads on one end and the lead wire you were expecting on the other end. Take a look at Pelican Parts Catalog for more details. It will also show location. Good luck. |
| detoxcowboy |
Apr 20 2009, 10:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Thanks! Where does the #1 Air Temp Sensor mount? Kris, The reason its different is because that's the Air Temp Sensor #1 (of two - the other is smaller and in the plenum -air box) The head temp sensor is about the diameter of your finger, with threads on one end and the lead wire you were expecting on the other end. Take a look at Pelican Parts Catalog for more details. It will also show location. tempsensor#1 is in the plenum right next to temp sensor 2 which is in your picture and is apparently the mount had broken free from the plenum.. the head temp sensor is under neath the engin tine behing a hole next to spark plug#3 here is a link to what is what and what does waht and why.. boring but priceless trouble shooting guide.. http://members.rennlist.com/pbanders/djetparts.htm also more easy info here,, http://www.rennlist.com/techarticles/djetronicfuel.htm also do not forget to look at google image search for 914 engine or components alot of time you will find a picture of your engine with everything in its place.. Good luck. |
| kpfoten |
Apr 20 2009, 10:17 PM
Much thanks! This has been fun--hopefully I'll get it running...
| Cap'n Krusty |
Apr 20 2009, 10:56 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
You've just thanked someone for the WRONG INFORMATION! That's the thermotime switch, part of the cold start circuit. Temp sensor 1 screws into the side of the plenum, and has a 2 wire plug in connection. The TTS attaches to a case through bolt, along with the forward leg of the plenum, on the right side of the case centerline close to the distributor.
The Cap'n |
| kpfoten |
Apr 21 2009, 07:46 AM
No, I just thanked him for the web links... (IMG:style_emoticons/default/smile.gif)
I will thank YOU for the exact location of the thermotime switch... So, thanks! |
| kpfoten |
Apr 21 2009, 08:59 AM
![]() Here's a photo that will give an idea (although probably not completely accurate): |
Lo-Fi Version | Time is now: 29th November 2026 - 06:58 PM |
