914 AC, somethings do work! |
SUNAB914 |
Apr 20 2009, 12:00 PM
Senior Member Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
I have a 75 2.0 I picked up last year. It was a great find. Beautiful white interior, AC and surprising not the usual rust. I took out the original drain plugs when I first go it. Under the rockers, is still clean bright original paint. The car was a garage queen with 47,000 miles and hadn't been ran since late 80's from the oil changes and registrations i found with the car. It's a twenty footer for paint, but just because dings and scraps, but once I used some rubbing compound on the white paint it came out real nice. The engine leaks oil from the usual spots, I'm going to do a complete resto in the future and have new Mahle pistons/cylinders waiting for that. That's the back ground. So with some time on my hands i replaced the AC dryer and seals I could find. I then put the 134 adaptors and charged it 134 oil to 2 1/2 pounds, went back and got it the car and low and behold nice cold AC. It was so exciting that it still worked. The compressor made some banging noise for a little while but that got quite after a few minutes. It may have to be rebuilt in the future, but for now it works. I'll try to post some pictures tonight, but I think I had a hard time with this sight last time because they needed to be smaller. (IMG:style_emoticons/default/driving.gif)
6freak |
Apr 20 2009, 12:48 PM
And dont forget the vin# for Andy ....cause if you dont (IMG:style_emoticons/default/sheeplove.gif)
SUNAB914 |
Apr 20 2009, 04:43 PM
Both my vin#s have been added. And I can't download pics, size is too big. Need help.
Apr 20 2009, 05:11 PM
Resident German Group: Admin Posts: 41,644 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The FAQ might help:
http://www.914world.com/bbs2/index.php?showtopic=13637 Save your pics as JPG with a medium compression (5) in 640x480 and they should be plenty small in filesize to post here. (IMG:style_emoticons/default/bye1.gif) Andy |
charliew |
Apr 21 2009, 11:11 AM
I have been told that the old R12 system oil needs to be completely removed or it will not be compatable with the 134a oil and freon. If the compressor croaks you can search and there are ac shops that specialize in vw changeovers. You can get a bracket that fits on the original bracket and it will hold a sanden type compressor also some of the kit suppliers claim that the condensor may not be big enough but I think they are just trying to sell parts. The old york compressor uses at least 7-8 hp and the newer ones use about 1.5 hp.
Lo-Fi Version | Time is now: 18th May 2024 - 11:47 PM |
