> 70' porsche ignition lock cylinder
mugentyper_msd
post Apr 21 2009, 01:31 PM
Hello all, I need some advice. I have a 1970 porsche in which I need the ignition lock cylinder. So I got part which is a Hella part ignition lock cylinder. Well further research I find that this hella part covers all porsche 914. I just know this can't possibly fit mine. I'm curious if anyone has had success installing this hella ignition lock cylinder in this 70'-71'. It seems to me 71' mid-year is the one in which hella makes the lock for this year and up. I have acutally modified the hella lock cylinder and now I can get it to fit but I shouldn't have to modify it in order to make it work. If anyone has any experience that would greatly help. Thanks in advance.
markb
post Apr 21 2009, 01:44 PM
914less :(
The wiring is a nightmare if you try to fit a 72 & up ignition switch in an early car. They changed it all around in 72.
Joe Ricard
post Apr 21 2009, 01:54 PM
CUMONIWANNARACEU
I did it, wiring wise. just got to trace out which pair of conections does what. then put the right wires on.
as far as getting it all to fit in an early car? GOOD luck!!!!! I finally gave up and swapped the whole column. Which is a real Muther Effer too.
- Lo-Fi Version Time is now: 12th January 2026 - 11:18 PM
