| championgt1 |
Apr 22 2009, 07:26 PM
Don't embarrass me Filmore! ![]() ![]() ![]() ![]() Group: Members Posts: 2,683 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/agree.gif) with Jon. Get the timing checked right away. From the video that idle is very high. How high was it 3 or 4 thousand rpm? Check for a MAJOR vacuum leak. When my car idled that high I chased all the vacuum lines and it ended up being a cracked intake plenum. Good luck. Glad you got it running. A little fine tuning and you are there.
| swl |
Apr 22 2009, 07:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
Yes, it can also make it hard to start like the sound it was making before it caught. So find someone that knows how to set timing and get it done (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) other culprits can be one of the vacuum hoses off - dumps air into the plenum. Don't go messing with the ECU until you check out both of them. |
| jcambo7 |
Apr 25 2009, 11:33 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,702 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/agree.gif) with Jon. Get the timing checked right away. From the video that idle is very high. How high was it 3 or 4 thousand rpm? Check for a MAJOR vacuum leak. When my car idled that high I chased all the vacuum lines and it ended up being a cracked intake plenum. Good luck. Glad you got it running. A little fine tuning and you are there. I actually don't know what it was idling at at all. My tach isn't hooked up all the way yet. Another thing to fix... (IMG:style_emoticons/default/headbang.gif) I am assuming its around 5 to 6 thousand rpm's. I will definitely check for a vacuum leak and it looks like I need a timing light. I need to find out where the intake plenum is too. |
| Sleepin |
Apr 25 2009, 11:38 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
(IMG:http://www.vwbughead.com/412fast/412manualtrans/914RunnerBusPlenumRusty.jpg)
The black thing that your intake runners get connected to. (this is a pic of one upside down) Plenty of chances for a vaccum leak there. (IMG:style_emoticons/default/wink.gif) |
| McMark |
Apr 25 2009, 11:46 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Make sure you have a throttle return spring on it.
Lo-Fi Version | Time is now: 1st May 2026 - 07:13 PM |
