| Rav914 |
Apr 23 2009, 11:53 AM
All-weather fan ![]() ![]() ![]() Group: Members Posts: 743 Joined: 15-April 07 From: WA Member No.: 7,669 Region Association: None |
The blower motor on my '70 will not turn on. I did some research and read through the following thread.
http://www.914world.com/bbs2/index.php?sho...l=blower++motor The switch and fuse/relay are good, clean, and have continuity. I pulled the wires from the motor and connected the leads directly to the battery with no effect. I'm assuming the motor itself is bad, am I correct? Thanks, |
| dbgriffith75 |
Apr 23 2009, 05:47 PM
TheGrif ![]() ![]() ![]() Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest |
If you put the leads directly on the battery and it didn't turn on, it's likely shot. I don't know of any other way to test them, so maybe someone else can tell you what to look for.
On the other hand, I do have a good blower motor handy. It's off a '75 and I don't know if they'll interchange, but if they will I'm happy to sell it to you. |
| tod914 |
Apr 23 2009, 05:59 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
You can repair them sometimes. Take off the back metal sleave and look and see if both wires are soddered on. Might be one broke loose.
| 76-914 |
Apr 23 2009, 10:35 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,943 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Did you check your ground? Mine is a 76 and I think I remember it sharing a ground with the WW switch???
| Rav914 |
Apr 23 2009, 11:00 PM
Yeah, I thought if the battery couldn't make it go, it's a goner. I'll take it apart this weekend and see what I can see. Thanks.
| Sleepin |
Apr 24 2009, 03:02 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
Just take her wedding ring off!
......I am really sorry, I tried for almost two days to resist typing that! (IMG:style_emoticons/default/laugh.gif) |
| Rav914 |
Apr 24 2009, 05:15 PM
Lo-Fi Version | Time is now: 23rd August 2026 - 04:02 PM |
