Door panel restoration:, 1 down, 1 to go |
rjames |
Apr 23 2009, 03:45 PM
I'm made of metal Group: Members Posts: 3,939 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
This job was a bit of a PITA and took much longer than I thought it would. However, the price of doing it myself is roughly $25 per panel, so it wasn't a hard choice to make over buying premade ones.
I did have cut new panels out by hand because mine were thrashed with speaker cut outs from othe previous owner. I ended up using early door panels for the template (I have a late model car), and bought the 2 metal strips that you use to hang the panel to the door from another 914world member. I decided not to use the basket weave material because I think the plain vinyl looks so much cleaner. Turned out pretty good. I just have to mount the door pocket, and then start working on the passenger side one next. A big thanks to Aaron for his thread on how to build GT door panels. I borrowed much from his ideas. My only deviations were to use balsa wood for the 'tuck and roll' backing strip, and also I did not glue the vinyl to the panel board. |
Lo-Fi Version | Time is now: 27th May 2024 - 11:18 PM |
